996 Forum 1999-2005
PCCM Plus Woes + Upgrades
Old 07-07-2023, 01:49 PM
  #76
pdxmotorhead
pdxmotorhead's Avatar
The 03 With Bose+most is also a snowflake from what I can tell. It looks like they used the Cayan head unit which is different in some way?
The compatibility lists so far all seem to leave the 03 out. Even a lot of the Most adapters I can find in the market stop at 02 in their lists..
Anybody happy with a PCCM upgrade in a 03 Cab with Bose?
Cheers
Old 07-31-2023, 04:39 PM
  #77
misterted
misterted's Avatar
I recently installed the PCCM+ in my 2004 Turbo Cab. Newer unit so no time issues and no odometer issues.
The issue I'm having is that every time I start the car, the last input I used (either Micro SD or Tuner) blasts on and scares the crap out of me.
and I can't seem to find a way to shut the music off and have waze give me spoken directions via Android auto.
Anyone know how to handle this? I read the manual to no avail and I'm hoping it's something easy I missed.
Old 07-31-2023, 04:42 PM
  #78
saxonthebeach
saxonthebeach's Avatar
Can you post a screenshot of your s/w version numbers? I also got a "new" (packaging was dated 2022) unit recently, but it had the same software version as my old unit from 2 years earlier.
Old 07-31-2023, 05:07 PM
  #79
misterted
misterted's Avatar
Old 08-02-2023, 04:44 PM
  #80
saxonthebeach
Thanks. FWIW that OS version number is the same I've had on 2 units, one purchased in 2021 (2020 mfr date) and one purchased last month (2022 mfr date).
Old 08-02-2023, 05:22 PM
  #81
misterted
misterted's Avatar
How do you turn off the tuner and be able to use waze with alerts?
Old 08-02-2023, 05:32 PM
  #82
saxonthebeach
Only way I know of is to start playing music on my phone via CarPlay, then quickly pause it.
Old 08-27-2023, 05:44 AM
  #83
jury_ca
jury_ca's Avatar
Anyone with a MOST car that has the low level static from the speakers in the dash and the rear when the PCCM + unit is switched on? The signal is not volume dependent and is not amplified. All the cars that have this distortion seem to be non-MOST cars.
Old 08-27-2023, 09:43 AM
  #84
TC2
TC2's Avatar
Wrong information.
Old 08-27-2023, 10:03 AM
  #85
misterted
misterted's Avatar
Mine sounds clean and amazing. No sound issues.
Old 08-28-2023, 10:14 AM
  #86
PorscheCambs
Cruisin'
PorscheCambs's Avatar
My setup is PCCM+ in 987.1 (2005) with ASK amplifier. I have the white noise on mute, alternator breakthrough & digital interference. Volume was way too sensitive. I believe this is a problem with analogue amplifier config where head unit is amplifying (I suspect pre-out with MOST doesn’t exhibit same problem). Dealer suggested a temporary fix using the custom equaliser setting with all ranges set to min. This partly solves the volume sensitivity, doesn’t do anything for the white noise.
Old 08-28-2023, 10:26 AM
  #87
frederik
frederik's Avatar
Sounds just like my problem, see post #47 by jhomer for the fix. You need an adapter cable. Strangely no dealers seem to know about this even though it’s a Porsche part.
Old 08-28-2023, 10:36 AM
  #88
PorscheCambs
Cruisin'
Yes, I know about the Porsche Wiring Harness, it was developed for the 986 with external amplifier. I wonder if it is the solution for the ASK amplifier, as some speakers are driven direct from head unit in this configuration. Porsche dealer has raised a problem report with this suggestion. I am waiting to hear response.
Old 08-28-2023, 12:34 PM
  #89
PorscheCambs
Cruisin'
Regarding your mute white noise issue, any fix? I have a 987.1 with ASK amplifier and recent fit of PCCM + by Porsche dealer. Two months since and no fix forthcoming. It seems to be a problem with the design of the PCCM+ head unit, and from what I’ve read on forums it has been there since the PCCM+ was introduced.
Old 08-28-2023, 05:01 PM
  #90
Body In White
Body In White's Avatar
I have the white noise problem with a PCCM+ on my 996 GT3 (no MOST, no external amplifier). I bought the cable jhomer referrenced and it didn’t solve the problem for me. I’m happy to sell it someone if they want to see if it fixes their problem with a non-MOST external amplifier. PM me.
Quick Reply: PCCM Plus Woes + Upgrades
