Hazard Trim Phone Mount
#271
I have used the magsafe apple phone charger but my phone falls off with some light bumps! Went back to a grip mount! Anyone find the mag mounts that hold the phone SECURELY?
#272
Dranon (02-26-2024)
#273
The following 3 users liked this post by yaz996:
#274
I found the the actual Apple branded magsafe charger to be weakest of the magnetic chargers I tested. The ESR Halolock is what I'm using now. When I start driving the 996 again in a couple weeks (weather dependent), I'm going to test out Quadlock's line of magsafe products.
#275
I'm testing out Peak Design, in case you're interested; their selling point is that although they are MagSafe compatible with a decent magnet and all that, if you really need the phone locked in they actually have a positive mechanical lock in their phone case. Very neat idea.
#276
Brilliant product you got here Yaz!
I will probably be buying a 17mm mount myself as soon as i sort some things out in the interior, but i have a question as it seems you are well versed in the center console wiring at this point:
Do you have a suggestion for hooking up a USB fast charge dongle for us guys with the in-car phone module connectors occupied? (Car currently features a period correct Nokia mobile phone )
#278
#279
@yaz996 Was just looking on your site and it doesn't seem like the regular 17mm without the charging cable hole is available. Is that coming back or no?
#280
All good. I had the same though actually and just placed an order for the one with the cutout. Let me know if you can see it. Thanks again!
#281
Is the Nokia actually functional? If not, I'd just leave that unplugged. If you're actually using it, the quick and dirty method would be a couple T-taps but I'm guessing you don't want to mar the wires. A splitter is on my list of things to do (and one other Rennlist member I believe), but haven't had much time to do anything lately.
Either way, would be very interested in a splitter type product if/when you get a chance to look into it! Cheers.
#284
Extra 17mm Ball
I got the Quadlock version and the phone power cable. They are awesome!
When will extra 17mm inserts w/ cutout be back in stock? I am going a different direction and the 17mm insert will be perfect.
#285
chicken butt (04-19-2024)
