996 Forum 1999-2005
My Build thread..
Old 08-16-2022, 10:08 AM
  #181
plpete84
plpete84's Avatar
Received 1,833 Likes on 927 Posts
Originally Posted by wdb
Man, if that was hanging under the back of my car I'd have a skid plate protecting it. I've already 'modified' the stocker once...
There is a bump protector that is missing on there. It should have come in the package. It's a small rectangular block that bolts to the bottom rear center, right behind the drain plug. Below you can see it on mine. I think a cover would be a good idea for street driving but wonder if it would have an effect on cooling with the fins being covered up from air flow.
The following 2 users liked this post by plpete84:
Justin76 (08-16-2022), wdb (08-16-2022)
Old 08-16-2022, 10:37 AM
  #182
GC996
GC996's Avatar
Received 3,917 Likes on 2,232 Posts
Justin, you have done an incredible job with your car. Preventative service, parts and procedures, set-up and looks are all well done. Congrats man.
The following 2 users liked this post by GC996:
Justin76 (08-16-2022), TheChunkNorris (08-16-2022)
Old 08-16-2022, 12:50 PM
  #183
Justin76
Justin76's Avatar
Originally Posted by audiophile35
@Justin76 Hi - I'm new to Nashville .... would like my Targa ceramic coated and PPF installed. Do you have a shop that you recommend? Thanks.
I only trust one guy.... The detailed experience and ask for Chris Johnson .. Tell him Justin with silver 911 sent you.. he is the absolute best.
​​​​​​https://thedetailedexperience.com
Old 08-16-2022, 12:51 PM
  #184
Justin76
Justin76's Avatar
headers are actually a little lower than the sump.....
  #185
Justin76
Justin76's Avatar
Oh i know.. took the picture before we finished ..
plpete84 (08-16-2022)
Old 08-26-2022, 03:56 PM
  #186
Justin76
Justin76's Avatar
While waiting on the rest of the suspension stuff to come in I did some research on headlight and taillight upgrades.
I upgrade both with some new bulbs from Retrofit Source .
I was tired of how crappy the standard halogen reverse lights and wanted to try to get more light also out of the headlights.
I found the following are easy upgrades in the link above that are all laid out for you in the 996 platform.
I upgraded to the Philips DS2 85112 XV Gen 2 bulbs. They definitely made a difference in light output for my HID's. The color is a little more white than the stock bulbs and produces more lumens which can be seen in the video testing
And before you ask i didn't get a before and after of the headlights but it was a noticeable difference for sure.
The reverse lights are a gigantic improvement over the OEM. .. you can see the difference below .. sorry for the bad photos as they really don't do them justice.
OEM light
GTR Bulbs
Here is the packaging .. they also come with some adapters to fit with the kit if you use the website and type in the vehicle information.
The following 2 users liked this post by Justin76:
plpete84 (08-29-2022), TheChunkNorris (08-26-2022)
Old 08-27-2022, 03:05 PM
  #187
dporto
dporto's Avatar
Received 1,167 Likes on 796 Posts
Did you do the reflectors as well, or just bulbs? I had done the bulbs in mine but found it didn’t help much… The reflectors made a huge difference!!! They’re on a par with modern light now…
Old 08-27-2022, 05:20 PM
  #188
Justin76
Justin76's Avatar
I assume you mean the projectors as mine is the bi xenon/hid? I didn’t replace the projectors and still had a noticeable difference.
I may up the wattage by modifying the oem ballast from 35w to 46w which is suppose to be a huge jump in lumen output.
Old 09-01-2022, 05:39 PM
  #189
Justin76
Justin76's Avatar
Some suspension goodies came in today…next up is to install, corner balance, and align again.
The following 6 users liked this post by Justin76:
dporto (09-02-2022), GC996 (09-01-2022), jobyt (12-10-2022), plpete84 (09-02-2022), TheChunkNorris (09-01-2022), zbomb (09-01-2022) and 1 others liked this post. (Show less...)
Old 12-09-2022, 10:30 PM
  #190
Justin76
Justin76's Avatar
Well it’s been a bit so I thought I would update this thread on what all has been done.
finally was able to start on the brakes.. I did Girodisc front and rear with akebono street pads. I also did Spiegler lines and Castrol SRF fluid flushed and bled. Much improved feel and ready for the track with a simple pad swap.
It was the perfect time to add the joe toth dive planes I’ve had for a bit (nice pieces)! It was the perfect time because I did to replace the cup splitter due to some **** poor judgement on my part leaving a gas station in a hurry.. I also ended up bolting the cup splitter in instead of using the plastic fasteners… good times 😂
I also got the elephant arms and camber plates installed. Corner balance and alignment came soon after.
GC996 (12-10-2022), golock911 (12-10-2022), plpete84 (12-10-2022), Ratchet1025 (12-09-2022), Tom Loder (12-10-2022), zbomb (12-10-2022) and 1 others liked this post. (Show less...)
Old 12-10-2022, 09:47 AM
  #191
dporto
dporto's Avatar
No, I meant the reflectors (the reflective “bowl” that sits behind the bulb) - this is the part of the “projector housing” that degrades the most over time, as the reflective material becomes non- reflective.
Old 12-10-2022, 10:19 AM
  #192
Justin76
Justin76's Avatar
gotcha.. I have not replaced them
Old 12-10-2022, 10:24 AM
  #193
zbomb
zbomb's Avatar
Received 4,292 Likes on 1,812 Posts
Man - I wish all those sexy parts were on when I last saw it, feeling like I got a bit short changed.... Lookin real good.
Justin76 (12-10-2022)
Old 12-10-2022, 10:55 AM
  #194
Justin76
Justin76's Avatar
they all were except the dive planes 😉
Old 01-11-2023, 09:36 AM
  #195
Justin76
Justin76's Avatar
I want to update the list since some things have changed and some things coming soon..
Maintenance items
All Spark Plugs and Coil packs replaced
OEM engine mounts
all new filters (cabin, air, etc..) and oil change switched to Driven
Water pump with full flush
160 Thermostat
Drive DT40 oil
LN Drain plug
Changed manual trans fluid with Mobil 1 Mobilube PTX 75W-90
LN IMS solution
UAOS
RMS, Clutch, and Flywheel
Lot’s of plastics changed such as al fender linders front and rear, windshield cowl, etc..
Lot's of hoses and other rubber items
Suspension
all suspension arms replaced with fresh OEM arms
Elephant LCA and Camber plates
Ohlins Road and Track coilovers
Tarret sway bar drop links
Performance changes
Fabspeed Max flo Exhaust.
FVD Headers and FVD Catless X pipe
FVD Tune
CSF Radiators including CSF center radiator
BMC Air Filter
UIDS sump
Exterior
OEM GT3 front bumper
996 GT3 Cup lip
OEM Aero Decklid
Aero Side skirts
Joe Toth Dive planes in Carbon
Ceramic coated and paint corrected
Interior
OEM carbon center console
OEM carbon radio surround
Rennline dead pedal and full pedal set
Rennline phone mount
OEM GT3 RS shifter
LLumar FormulaOne Stratos 70%
Brakes
Giro Disc front and rear
Akebono street pads
Castrol SRF fluid
Spiegler stainless brake lines
OEM 997 GT3 brake ducts
Race pads – undecided but most likely Ferodo DS1.11
Wheels and Tires
Apex SM-10 wheels gt3 fitment with Conti tires 235/ 295
Changes coming soon for
Wheels and tires
Tarret Sway bars
OEM GT3 RS steering wheel
Numeric shifter and cables
BBI Roll cage
Rear seat removal
The following 4 users liked this post by Justin76:
damage98MO (03-17-2023), EVOMMM (03-17-2023), JohnCA58 (01-11-2023), Ratchet1025 (01-11-2023)
Quick Reply: My Build thread..
