"new" C4S and engine rebuild; bad bore score
#241
Im sure there r many threads in the turbo section for front axle elimination.
While i have not done it cant u just get 2 axle stubs from a junk yard like dc auto, remove the front diff, axle shafts and driveshaft and be done? U dont need to swap uprights or shocks eventhough it would be best for suspension geometry.
#243
e30rapidic (12-28-2023)
#245
I reuse the axle nuts because the old ones have a floating washer which the new ones don't. I doubt the locking element has much effect on a 400 nm torqued nut anyway.
e30rapidic (12-29-2023)
#246
#248
The bag part# paf001784 is a valid number in the Delaware porsche online catalog. The original number i got off autoatlantas site was 99908464101. This part # matches the bags i have from fcp and they were all floating washer too.
#249
Managed to get the 82mm IPD plenum and “GT3” throttle body installed this afternoon. Did a throttle adaptation beforehand and it cranked right up first time. Hopefully I can take it for a drive early tomorrow…
#250
That thing sounds very, very good. What mufflers are you running?
How did the connector pipe from the air box the TB work out? I need to work this out as well.
#251
It’s a full Fabspeed exhaust with an X pipe. I used the IPD supplied boot for now; tight fit but that could be because I flipped it around to hide the logo.
Realised one thing I do need to work on though, I totally forgot the Tiptronics used a Venturi tube to bypass the throttle body. I’ll get the manual version installed one day as I don’t want to install a breather vent. So for now the open end is blocked off with electrical tape. Yes, electrical tape.
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
And the engine bay needs a dang good clean since I painted and wetsanded it. Kinda embarrassing to
be honest.
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_4190_5a271283de4d71b135637c65cefd880ea52ea64c.jpeg)
#252
The following 2 users liked this post by De Jeeper:
bmchan (12-30-2023),
e30rapidic (12-30-2023)
