996 Forum 1999-2005
Yaz's Rebuild
Old 05-10-2020 | 09:26 PM
  #316
Scott at Team Harco's Avatar
Scott at Team Harco
Just a car guy
Originally Posted by yaz996
Pretty much decided that I'm pulling the engine and putting it back on the stand. Cam covers are coming off, and I'll scope the cylinders before deciding if pulling the heads is necessary. Went with the ARP head studs, so at least I don't need to worry about those being TTY.
Yeah - dropping the engine and getting a good look makes the most sense.
Old 05-10-2020 | 09:31 PM
  #317
dporto's Avatar
dporto
Wow major bummer. Nothing more to say at this point - hoping for the best possible outcome...
Old 05-10-2020 | 11:51 PM
  #318
Imo000's Avatar
Imo000
Captain Obvious
Super User
$hit! Those pieces look a lot like crank and/or rod bearings to me.
Old 05-11-2020 | 12:15 AM
  #319
jjbravo's Avatar
jjbravo
Sad. Sorry for you. That is a real gut punch.
Something terrible is definitely going on.
Old 05-12-2020 | 06:57 AM
  #320
Noz1974's Avatar
Noz1974
Hey yaz, just keep going I'm sure you'll get to the bottom of the problem, seems strange something like this , your build was looking amazing , meticulous and clean , I can't imagine how you must feel , like you say though at least you got arp bolts so even if you strip it down maybe a few gaskets and seals to get it back together! I'm sorry to say the copper coloured debris does look like main/big end bearing , I really hope not, maybe Jake will chime in .
Good luck buddy keep fighting the good fight!
Old 05-12-2020 | 09:33 AM
  #321
yaz996's Avatar
yaz996
Thanks for the suggestions. Spent a good amount of time tracing my steps. I'd say the prevailing theory is there was a blocked oil passageway to one of the bearings. Possibly some debris leftover from the work done on the crank (magnaflux, polish, balance, and clean). Unfortunately, the one missed step that I can identify is I never verified the passageways were clear.
Old 05-14-2020 | 08:02 AM
  #322
Splitting Atoms's Avatar
Splitting Atoms
Your theory of a clogged crank oil passageway seems logical to me. A failed rod bearing (most likely in my experience) would explain the loss of oil pressure and the debris. It's likely the debris have affected the other bearings and engine components. I would be planning on a tear down to the crank. My hope would be that the cylinders are not scored.
Old 05-15-2020 | 05:39 AM
  #323
Uber996's Avatar
Uber996
I just wanted to add some sympathy to your position Yaz, I'm only a recent owner and was following your build with great interest since my car was a comparatively cheap high miler and I won't be surprised if I have to do something similar before too long. I really liked the way you worked, in all the photos I thought this guy is doing it how I would do it. For you to encounter problems is a sobering thought to those of us who look on thinking they will need to do the same at some stage.
I thought I'd share that the first proper engine rebuild I did was in the mid 90's on my quite unusual Italian motorcycle, with parts that were hard to source at the time and very expensive for me relative to my income then. I spent a year or so with many problems encountered and overcome along the way, and when I fired it up it ran for about half and hour and then nipped up an exhaust valve in the guide and started making terrible noises. I was pretty devastated. I pulled it all down again and did it again, I was lucky and there wasn't too much damage, just a bent valve and damaged guide really, but I had to do the damn head all over again anyhow. It was 25 years ago and I still remember the feeling first of elation when it fired up, then dismay when it all went south. So I thought I'd just send some positive vibes. After overcoming the issue I rode the wheels off that bike and it's still going now, with that same engine build, and I still love it... in no small part due to the trials and tribulations we went through together during that engine build.
All the best
Uber (Steve)
The following 6 users liked this post by Uber996:
cwbrown (05-15-2020), hatchetf15 (05-15-2020), jjbravo (05-15-2020), jobyt (05-15-2020), Ratchet1025 (05-16-2020), TexSquirrel (05-15-2020) and 1 others liked this post. (Show less...)
Old 05-15-2020 | 04:50 PM
  #324
jjbravo's Avatar
jjbravo
Yaz, we look forward to your discoveries and pictorial of the teardown.
hopefully it’s a quick fix and not too much money. .
Old 05-15-2020 | 06:07 PM
  #325
yaz996's Avatar
yaz996
Everyone following this thread will be getting their (my) monies worth. Just hope I'm finally on the upward slope of the plot below:
The following 8 users liked this post by yaz996:
dporto (05-15-2020), jjbravo (05-15-2020), JMattKTM (05-15-2020), jobyt (05-15-2020), latonnelier (05-15-2020), rx7dude (05-16-2020), Scott at Team Harco (05-15-2020), TexSquirrel (05-16-2020) and 3 others liked this post. (Show less...)
Old 05-15-2020 | 06:12 PM
  #326
DBJoe996's Avatar
DBJoe996
At least you have maintained some sense of humor! So hoping there is not collateral damage found....fingers crossed. Amazing build, hoping for the best.
Old 05-15-2020 | 07:19 PM
  #327
Noz1974's Avatar
Noz1974
Yazz
I think once you accept what's happened which you seem to have pretty well!! You can move forward with new goals! Just be prepared , I'm guessing your heads and cases will be ok, I'm thinking it's chewed up the main bearings or rod bearings , you know the crank will probably be toast ! I think you will need so source a good used crank as they are case hardened and can't be re ground (ask me how I know!) I'm in the uk but know some good dismantlers here so I can possibly help if needed , good luck and keep posting the updates , you will get there ok
Old 05-15-2020 | 07:31 PM
  #328
yaz996's Avatar
yaz996
Originally Posted by Noz1974
Yazz
Crank condition will be the big variable. Going to have the local shop that did the work check it out. That'll be an interesting conversation. Worst case I'll be getting a crank from LN, but if anyone has a source for a quality (non-spun bearing and polished for show eBay special) crank it would much appreciated.
Old 05-15-2020 | 08:35 PM
  #329
Quadcammer's Avatar
Quadcammer
I believe you would need the matching crank carrier as well. I seem to recall line boring these carriers is not a done thing
Old 05-16-2020 | 09:37 PM
  #330
yaz996's Avatar
yaz996
Definitely don't want to make this a habit, but pulled the engine in under 5 hours this time. Never recharged the A/C so I did save some time by not dealing with that.
The following 4 users liked this post by yaz996:
JohnCA58 (05-17-2020), kingroon (05-17-2020), latonnelier (05-16-2020), Scott at Team Harco (05-16-2020)
Quick Reply: Yaz's Rebuild
