I bought the cheapest Porsche on Craigslist and the IMS bearing has failed.
My 2cents
I agree with Hatchett's post and others...Job 1: Get an expert's opinion on the internal damage, then make decisions on a re-build, replacement, or.
The looming question is whether it has suffered a "catastrophic failure". If so, the costs of re-build soar to about $15K or more. If not, then a used engine can/will cost $5-9K, not counting shipping, installation, and "while we're in there stuff." These engines are very complex...only re-builds by an expert should be considered...amateurs need not apply.
relinuca
relinuca
All great advice, but it boils down to setting "your" budget first. Second, what's your total(car + rebuild) budget? If your numbers look good, then this should be a great learning experience and fun project to tackle.
I have no mechanical skills, never been on RL, never owned a Porsche but I paid cash for a non running 996 with no PPI.
Did we get that right?
Not trying to be negative but this is a good lesson for others, if this is legit, how not to buy a car.
Ouch. With every start more damage occurs. Don't start it again until it's fully rebuilt. You should also bore scope the cylinders to see the condition of the bore surfaces. Follow Jake's videos on YouTube.
What's the point of scoping if the motor needs to be torn down and opened up?
I would be very interested in that class.
One of the reasons I chose this car is because it was so original, I'd like to keep it that way, so an LS (or other non-M96/03) swap is not in my future.
The seller did start it for me, I had him shut it down quickly though, no sense making it worse.
like others said, drop the pan and have a look see, I'd also pull the plugs and scope them, then hand rotate the engine to see if it rotates ok
If it does, next thing I'd do is drop the tranny and pop the IMS cover off and take a look
Like the advice to drop the sump versus just examining the filter, this would help confirm the extent of the damage. If for some reason, unbeknownst to anyone at this time, the cylinders are NOT suffering from scoring, then that may give the OP some new found options to save money especially if he's rebuilding it himself.
Bob Dobolina (07-30-2019)
Shameful Thread Killer
And now, for something completely different.
I know of two engines that had IMSB failure, but were caught in time, and the engine oil circuit was flushed, the IMSB was replaced, and the engine ran. This is not an endorsement, nor is it a plan for one to follow, just that 'catastrophic' and marginal failure are two different things.
How much would it cost to replace only the IMSB? couple hundred.
How long will it last? From 2-200-2000 miles. Maybe
YMMV, objects in mirror, pro driver closed course, contents have settled, and may cause **** leakage.
^^Thats probably on the high end of what it’s actually worth. How much did you research before you bought it? Do you realize to rebuild the engine properly (even if you do it yourself) is going to run in the $15k range? If you do, and you’re up for it, more power to you! 👍
