500hp+ 993 Club? Owners please come in.
#136
I need to add another oil cooler to mine and a trans cooler would be a nice upgrade at the same time. Which LSD are you using?
#138
I use two 993 oil coolers and have *zero* oil temp issues. For an LSD don't waste your time and get a guard with 50/80 lockup
#139
I know the Guard units well because I had them in my last two Porsches. They work very. My Quaife LSD is amazing at putting down a lot of power in a smooth and controlled fashion but it leaves a bit to be desired under hard braking. This never an issue on the street but at 10/10th going for broke on the track a Guard would be nicer.
#140
The LSD is stock with the Porsche RS plates upgrade.
Trans cooler is the Porsche internal oil squirter bar, with an external electric pump, and a heat exchanger with fan in the driver-side rear fender (the Porsche mechanical internal pump was just too expensive).
I had the trans rebuilt and upgraded by California Motorsports with a goal of handling 550 lb/ft of torque and heavy track use.
#141
#142
Shrouding is of course very important, less so with the Secan since it is so efficient that it could maintain ambient +20DegC regardless,
Here is a wing on Secan - looks like a fair attempt has been made to direct the airflow:
#143
... you are now making statements about other things based upon an analogue gauge which may or may not be giving you actual IATs as seen by the ECU
Powered by digital microprocessor-controlled, rugged stepper motor drives & laboratory grade sending units, Full Sweep Electric Gauges are the BEST gauges available. They combine Extreme Durability & Readability of 270 degree sweep mechanical gauges w/ the Easy Installation & Safe Operation of short sweep electrics. Track Tested & Race Proven, these units use precision senders to keep hazardous fluids out of the driver compartment, and perform gauge calibration and sensor diagnostics at power up for Extreme Accuracy, every time.
My intercooler kept the IAT below 100F (or less than +20F above ambient) for mutiple laps of a race track, even after numerous WOT run to 160mph and lots of WOT at lower speeds (less airflow over the IC).
#144
I take your automotive quality gauge:
And raise you one made for aviation:
+/- 1% it may be but it does not react as fast as the the sensor the ECU reads, it can miss the peak IAT by 10DegC....
I'm just trying to persuade you to "be bothered" enough to plug in your fancy dash and read real IAT, I am interested
See what you mean about the Secan sealing, the racers didn't seem to bother and I don't think there was a factory (motorsport) shroud solution available and as I said before not necessary for that amazing piece of kit - for all other tho' shrouding is the way to go IMO
#145
Tell me more about the (Bosch?) sensor that measures the IAT for your Motronic DME (Hammer readings). Where is it located? I hope it is more accurate than the original narrowband O2 sensor that feeds the Lamda signal to the DME
Let's sign off on the IAT discussion until new data can be brought to the table
What suspension package does your blue beast use to harness all that power and torque?
#146
The kit was very comprehensive - if you can make out the parts below:
The shocks were way too stiff and were replaced by PSS9 and the top mounts are currently FVD solid billet units.....
BBS race 9X18 fronts with 225/40
BBS race 11X18 rears with 285/30
The car handles pretty uniquely for a 993tt, the road tester agreed:
#147
Can you please post info on the IAT sensor? I would like to install one in my car. I've got a DashDAQ data logger connected to several other sensors, but I'm currently only use the OBD2/Factory IAT readings and would like a better (accurate and responsive) sensor.
#148
1 Post
But i'm just a bastardized 930 with a hot rodded 964 block with some Andial P&C's and Protomotive IC and some other fun stuff built to a 3.8tt that sounds like an F1 motor.
We're retuning the motor with MOTEC so we can get gear dependant boost and actually get traction. 634rwhp at 1 bar and over 850 at 1.6 bar.
At 1.3 bar we're roasting the massive 15" wide rear tires even at triple digit speeds. We're hoping to pick up some more power up top with ITBs and better cooling using a flat fan setup like the 935's used.
#150
Guns951
You must have gotten bored by now to hear praise about your car, it is outrageous!
Do you have already any acceleration data for your lightweight 3.8 monster? We all have a similar engine and I can hardly break traction at 60mph with my 315s. Protomotive forgot a couple of hundred HP there strapped on his engine dyno
