Recommendations regarding a half-/roll-cage in a 993?
#91
Sorry, I was referring to the pic by oysteinw...he seems to have it mounted up higher on the side mount.
I'm trying to figure out, not to hijack the thread, what receptacle to get so that I can mount it low as in the pic above, but get it to come into the side Recaro hole. It is too hard to take the seat in and out with the receptacle in the way...
![](https://rennlist.com/forums/attachments/993-forum/754743d1377126700-recommendations-regarding-a-half-roll-cage-in-a-993-12_17_08_-0081229804000.jpg)
This is the same install in a friends car w/ PP seats and BK mounts, he reworked the RS mount a bit for a bbetter angle and height
![](https://forums.pelicanparts.com/uploads22/IMG_47141377170335.jpg)
Here's the same thing in mine using the RS mount and removing the plastic sheath
![](https://forums.pelicanparts.com/uploads22/3_7_10_+0011377169761.jpg)
![](https://forums.pelicanparts.com/uploads22/05_06_09_+0031377169908.jpg)
#92
Bill, what do you do about the seat belt light on the dash?
Also, I must have a different Recaro mount. I pulled off the rear receptacle (don't get dirty on me boys) and started to put it on the front, but it wouldn't reach from the RS mount point to the side hole.
I have this mount, which might be part of the problem.
![](http://www.northstarmotorsports.com/imageProduct3/1460.jpg)
#93
I have been looking at the Heigo roll bars and find they are made in styles for permutations of with and without rear seats and with and without sunroof as well as a weld in bar for cars without sunroof.
The bar for the 993 RS is made for no sunroof and no rear seats and has the rear going diagonal designed and mounted differently because of this.
Instead of a flattened tube going to the lateral rear seat belt bolts, it goes to the stub of tube with an 8 mm internal thread located at the rear seat pivot. Below, thanks to Benton's picture which I have marked in text you can see different mounting point. (I hope OK Benton)
![Name: 993-half-cage-1.jpg
Size: 236.8 KB](https://rennlist.com/forums/attachments/993-forum/1205999d1501333485-recommendations-regarding-a-half-roll-cage-in-a-993-993-half-cage-1.jpg)
Image of RS bar on Heigo website.
![](http://www.heigo.de/images/articles/10847_01.jpg)
Bar for car with rear seats in Macca's car (which has no seats), note flat tubes going to seat belt mounts
![](https://rennlist.com/forums/attachments/993-forum/725041d1367625292-recommendations-regarding-a-half-roll-cage-in-a-993-993gt600-9.jpg)
![](https://rennlist.com/forums/attachments/993-forum/725042d1367625292-recommendations-regarding-a-half-roll-cage-in-a-993-807e200277984418.jpg)
#94
CupCar. Thats a really interesting find. I think you are right. Looks like a totally different design as the X brace is at a different angle hence the top mounting taps on the hoop would need to be too. I think the RS design is inherently stronger as it doesnt use flattened tubes. I have some better pictures of this on file...I must say its the only RS cage I could find on google. Looks good.
#95
Woah! What a find! Seems that it might be able to be installed without removing anything other than the rear seatbacks and the tunnel side seat belt mounts?
#99
Sunroof version of their RS cage? I doubt it. The cage shown in yellow is apparently the same as the gold one in the photo below for a non sunroof RS although I have never seen this item for sale (even the pictures in the advert are conflicting)...
#101
A bit late to the party. Anyone found out if a proper RS cage like in the yellow car could be ordered from heigo? I do want to add a harness bar to it though. Sunroof delete is on the top of my to-do list at the moment.
#102
Mate. I dont think anyone was interested but I do believe they make it (not for sunroof). Contact Heigo and they should confirm. They are great cages - very happy with mine...
#104
FVD Brombacher, Inc.
Rhonda Roxburgh
5061 N.W. 13th Ave. Suite A
Pompano Beach, FL 33064
Phone: 954-571-2050 #14
Fax: 954-571-2060
E-Mail: rhonda.roxburgh@fvd.net
http://www.fvd.net
I won't be able to take pics until it arrives and car is here and that will be a while.
