993 Forum 1995-1998
Remote Key Fob Programming made Easy Revised!
Old Feb 8, 2018 | 04:48 PM
  #31
Jupiterfish's Avatar
Jupiterfish
Originally Posted by ECU Doctors
Morning guys,
Yesterday we did a quick video on how to program the Porsche 911 993 keyless entry remotes.
Let me know what you think.
https://youtu.be/2FXxd27JYgM
great video, i had no idea what everyone was talking about turning the key. Thanks
Old Feb 8, 2018 | 04:56 PM
  #32
ECU Doctors's Avatar
ECU Doctors
Former Vendor
Thanks! We "made it look easy".
Every car is different and can bring it's own challenges.
Old Feb 8, 2018 | 05:08 PM
  #33
Lorenfb's Avatar
Lorenfb
That's JUST the Porsche standard procedure most here on the 993 forum have used and discussed for 10+ years.
Have you missed those threads by chance?????
Old Mar 1, 2018 | 09:48 AM
  #34
Jay777's Avatar
Jay777
Thanks for posting ECU Doctors. A pic is worth a thousand words. I'll have to retry programming mine again this spring
Old Mar 1, 2018 | 02:10 PM
  #35
s4magman's Avatar
s4magman
Great video! Thanks ECU!
Old Mar 1, 2018 | 03:17 PM
  #36
pp000830's Avatar
pp000830
Morning guys,
Nice video!
Old Mar 1, 2018 | 03:39 PM
  #37
ECU Doctors
Former Vendor
Glad you guys liked it.
If you want us to make other videos like it, or something more technical let me know.
Old Mar 1, 2018 | 05:19 PM
  #38
Jay777's Avatar
Jay777
It was never really clear to me what the written instructions meant by "The immobilizer warning light will light up and flash". Seeing it in the video clears that up. Thanks again.
7 Porsche Models That Have Aged Like Fine Wine
Old Mar 3, 2018 | 04:14 PM
  #39
nine9six's Avatar
nine9six
...Proving once again that a picture or a video is worth a thousand words!
Old Jun 8, 2018 | 04:17 PM
  #40
Jay777's Avatar
Jay777
I finally got around to trying this again. Last year before the video, I tried the standard procedure without luck. I thought the clarification on the behavior of the warning light after each step, I'd have better luck, but no.
I get to the point that readies the car to accept the PIN OK, but my warning light behaves differently from that point.
In the video, after each OFF-ON "cycle" when entering a PIN digit the warning light is OFF then comes ON after a brief delay.
When I do it, after each ON-OFF stroke the warning light is ON (like all the others in the clock).
I verified the PIN from a Porsche dealer and really, I'm not even at the point where that could be the issue -- it doesn't seem to be accepting the ON-OFF cycle properly.
Anyone have any Ideas?
I tried the procedure exactly as shown in the video and also the other published ones I've seen here.
Old Jun 10, 2018 | 10:37 AM
  #41
pp000830's Avatar
pp000830
Originally Posted by Jay777
I
1: Is your car an example with an alternate key system, aftermarket or an early dealer installed option? Have you had your Motronic unit aftermarket-updated? The door lock controller fobs the instructions relate to originally came with a switchblade fob some converted to a 944 fob later on. If you have something other than this the procedure won't work.
Could you possibly be using a key turn technique that is not reliably working for the procedure? Can you describe in detail your key turn technique?
Old Jun 10, 2018 | 11:09 AM
  #42
Jay777's Avatar
Jay777
Andy- The switchblade key was converted to a FOB in 2015 by PO. I always assumed the difference between the two was just the way the two were packaged. Are you saying there's a different programming procedure for FOB and switchblade? That would certainly explain the problem. What's the procedure for the FOB? As for the key-turn technique - I did it exactly as shown in the ECU video.
There is one other difference I noticed between the way my warning light behaves vs the one in the video - in the step just before PIN entry - my warning light flashes much slower than the video.
Old Jun 10, 2018 | 02:03 PM
  #43
pp000830's Avatar
pp000830
Andy- The switchblade key was converted to a FOB in 2015 by PO. I always assumed the difference between the two was just the way the two were packaged.my warning light flashes much slower than the video.
Yes, it is only packaging. Sounds like you have the correct OE alarm/ immobilizer unit to use the instructions with.
Seeing that the flashing you note above seems a little slow to you I would check two things.
  • One being that the door alarm indicator flashes in single flashes, not couplets when the alarm is active, indicating no internal system faults with the immobilizer /alarm that would interfere with programming.
  • And that the system has adequate voltage when programming of 12.5 or greater volts using a volt meter to check at the battery,
Andy
Old Jun 11, 2018 | 09:24 AM
  #44
Jay777's Avatar
Jay777
Door alarm does flash in single flashes so that's not it. I'll check voltage later today.
I do know it's >13.5 when running (was troubleshooting something else yesterday), but have noticed slow cranking lately so that's a possibility.
Old Jun 11, 2018 | 08:57 PM
  #45
nine9six's Avatar
nine9six
Jay,
Here's the deal... If your ignition switch is in any way not functioning smoothly and properly as you "key in" your code digits, then the programming code could very well be going in incorrectlyly, which would explain it not working for you.
HTH
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
