M030 facts I did not know
#46
Shims
As we know, the front struts have minimal threads for height adjustment, and no threads on the rear, with rear height adjustable only by the use of an assortment of three (3) shims, 3mm, 5.5mm and 8.0mm. These are not very big shims.....
Be that as it may, let's not forget what a great improvement the rear suspension was over previous, and possibly later models, with the LSA (Light, Stabe, Agile) suspension and the bonus of kinematic toe...which can really help handling on deceleration. I am more than pleased with my 993 car's handling. It has never let me down, predictible. It actually serves to creat the illusion that I am a decent driver...My ABS and the LSA really helps with this. The Big Reds help too!
#48
I am sorry Bill, I have the PET6 and have never known there were cross-references with the TSB's. Could you tell me where in the PET6 is that? or is it the downloadable PET catalog you are talking about?
#49
Well, I just confirmed my unfortunate suspision...they sold me the Trubo ones!!! Thanks Geolab.
Originally Posted by geolab
993.333.531.11.504 M030 rear springs with brown stripes
993.333.531.16.504 Turbo rear springs with red stripes
#50
#51
I installed those by choice recently - with M030 bars: very pleased with the results ... so you may not be all that unfortunate ...
#52
Addicted Specialist
The answer I got today:
The 993 Turbo/ GT's/RS have a stiffened monocoque body compared to a normal 993.
Reinforcements exist all over the body at various emplacements.
Due to weight factor, weight has been compromised in other components and areas.
A stiff suspension will compromise more a non strenghtened body in street use, exposed to bumps, potholes, etc.
This is what they meant and personally, I agree with them.
They didn't have a 993 Turbo at the workshop, but we raised a GT3 to take pictures
you can see clearly, 2 visible areas were the body has been reinforced to compensate for the stiff suspension.
...sorry, just couldn't resist neither.
Geolab,
Please feel free to disagree with me ...I have no stake in this nor do I take much of anything personally. But do you really think that the mere difference of, say, going to a 250lb front spring, or dare I say a 275lb (ooooh!) is going to rattle those lowly TT, RS, or GT3 chassis more than the stiffened/reinforced NA993? I guess all those fools throwing in PSS9s and their attendant monster springs into those flexible flyers are going to lose some fillings ...or maybe it'll just rattle their POS chassis apart. I wonder which will occur first.
Edward
#53
Originally Posted by Bill Verburg
I will have to plead the 5th, but if you look on the US side you will see this, doesn't appear on the RoW side
the second .pdf is for curiosity
#54
Originally Posted by Garth S
LJ,
The set up will be great for AX and DE events but I don't think she'll see many more as I'll be looking for a TT in a few months and the cab will be strictly a sunny day driver for which I would've preferred the softer ride. That's why I made that comment, but you're right either way the car handles and looks way better. Pictures coming soon to a thread near you...
#55
Thanks Bill, got the page, it was updated and it concerns only the struts, unfortunately.
#56
Originally Posted by Edward
Geolab,
Edward
Edward
#57
Geolab,
The whole post started with why are there springs with two brown dots and others with three brown dots.
- 1st assumption "the springs are the same"
excellent !! Now to complete the strut assembly, you fall on a shim that fits above the spring.
This shim exists in three thicknesses, which one should you purchase?
A quick look in the Workshop manual for more info, and you discover each shim
for a different number of dots on the spring.
So the two dotted spring is not the same as the three dotted spring.
And the springs side by side, are exactly the same height.
Isn't any normal 993 enthousiast curious to knowing why?
or shall we also throw it on the conspiracy theory????
But do you really think that the mere difference of, say, going to a 250lb front spring, or dare I say a 275lb (ooooh!) is going to rattle those lowly TT or RS chasis more than the stiffened/reinforced NA993? I guess all those fools throwing in PSS9s and their attendant monster springs are going to lose fillings ...or maybe it'll just rattle the car apart. I wonder which will occur first.
Edward
Edward
From what I have learnt so far and on the long run? yes.
If you would like to discuss the chassis issue, I presume we should take it to another post.
Please read the second .pdf I posted above for curiosity (the last lines in particular)
Some have tried to ridicule this post while the only thing they ever do is ridiculize themselves
#58
Originally Posted by Bull
My 600lb front and 800lb rear springs, JIC Cross 15 adjustment shocks and H&R 26mm/24mm sway bars haven't caused a single rattle or creak...in the car or me (well, new creak in me).
#59
Thanks very much, you just filled sin some holes for me. I have been trying to collect the 993 tsbs. They are not easliy obtained.
#60
As for the stiffness of a chassis, I think you mixed up a bit in your quote here-above. Maybe you meant asking "if a stiff suspension is going to rattle a normal 993 more than a TT or RS?"
You seem to have am ability to select those "facts" that support your hypothesis, all the while throwing away any real evidence to the contrary.
