993 Forum 1995-1998
A Plug-and-Play, DIY-Installable 993 Immobilizer Defeat
Old 01-15-2020, 10:21 AM
  #166
Caveman
Caveman's Avatar
Oh OK. Sounds like they are both as crap as each other!
Cheers,
David
Old 01-15-2020, 10:26 AM
  #167
Jon 'Bama
Jon 'Bama's Avatar
can I be the cheap guy and ask about the price? That is where I decide need to have versus nice to have
Old 01-15-2020, 10:37 AM
  #168
Trevor-uk
Trevor-uk's Avatar
Originally Posted by Caveman
Meenrod - I think so yes. I have a 95 car with the rectangular block and I think it is late 95. I also have a small gizmo that I have to plug into a slot on the dash before the car will start. Recently, it has occasionally not made its bleeping noise when I inserted the gizmo but is still unlocking the car.
Trevor-UK - I'm not sure if it the same thing but it seems to have the same issues as the US cars. Do you have the little immobilser gizmo?
I have a '96 car. It is unlocked (and disarmed) using a fob, allowing me to start the car immediately with no further fiddling (no gizmo on mine but I know the one you mean) - if I don't start the car within 20 or 30 seconds, the starter circuit is immobilised (all lights will come on with the key but no click, whirr, brumm). When this happens I need to press the unlock on the fob again to re-enable it (for another timed period). This sounds like a similar process the US cars are following? I believe many UK cars were supplied from Porsche with a Hamilton and Palmer alarm system - maybe just a front end to the Driveblock?
Old 01-15-2020, 10:55 AM
  #169
Jay777
Jay777's Avatar
Originally Posted by LimeyBoy
Brilliant Jay777.
I'm interested.
Sorry if I missed, but does the new IMMO BLOCK I also have the switch to re-enable immobilizer?
Again, nice job.
Thanks for your interest and question.
Early on it was envisioned a switch would be incorporated to "re-enable" anti-theft protection, but that's no longer necessary. With the Immo Block you get anti-theft protection whenever you lock the car with the FOB - no need to throw a switch, unplug the unit or take any other special action - it's automatic. (This distinguishes it from ECU-based defeats which completely remove anti-theft protection).
Old 01-15-2020, 11:02 AM
  #170
Jay777
Jay777's Avatar
Originally Posted by Trevor-uk
Do we have this immobiliser in UK cars? If we do, does this device have the same function then as eliminating the re-arming of the PA1000 (Hamilton Palmer) alarm after a timed period?
Unfortunately UK Immos are different and would not benefit from this product.
  #171
Meenrod
Meenrod's Avatar
Yup, that's it. Mine is a 96 also. This was a feature added to OBD2 cars: 96-98 in the US.
Old 01-15-2020, 11:33 AM
  #172
Jay777
Jay777's Avatar
Originally Posted by JPS
Any update as to purchasing?
Lot's to do but on track for 1 March availability. Probably a limited pre-production run offered on a first-come-first-served basis.
MSRP? Waiting on quotes from suppliers but barring a major surprise it should be significantly less an ECU-based defeat. Hopefully the price and easy DIY will make this attractive to a wide audience.
The following 2 users liked this post by Jay777:
NC TRACKRAT (01-16-2020), SpeedyC2 (01-15-2020)
Old 01-15-2020, 11:48 AM
  #173
LimeyBoy
LimeyBoy's Avatar
Early on it was envisioned a switch would be incorporated to "re-enable" anti-theft protection, but that's no longer necessary. With the Immo Block you get full anti-theft protection whenever you lock the car with the FOB - no need or throw a switch, unplug the unit or take any other special action - it's automatic. (This distinguishes it from ECU-based defeats which completely remove all anti-theft protection).
Wow, nice one again Jay - thanks for your efforts. I'll be watching for release date.
Old 01-15-2020, 12:58 PM
  #174
SpeedyC2
SpeedyC2's Avatar
Does this mean using the physical key to lock and unlock the car keeps the anti-theft off?
Does the anti-theft switch off if you unlock with the fob? (And so then can be started any time, even if left unlocked for longer than typical re-arming of the anti-theft?)
This sounds great, regardless! Looking forward to the release.
Old 01-15-2020, 02:31 PM
  #175
territory145
territory145's Avatar
Default Immo
I would like one for my 1998 993 Cabriolet please.
Old 01-15-2020, 05:01 PM
  #176
Jupiterfish
Jupiterfish's Avatar
will this work on my ferrari 360 also?
Old 01-15-2020, 11:52 PM
  #177
mhm993
mhm993's Avatar
+993
Old 01-16-2020, 12:23 PM
  #178
Jay777
Jay777's Avatar
Exactly. The Immo has two OEM modes of operation "manual immobilization" and "passive immobilization". Manual immobilization is when you arm the system with the FOB (a good thing). Passive immobilization is when it arms itself (a PITA). Good cholesterol/bad cholesterol. The Immo Block stops passive immobilization but allows full protection when you need it. Best of both worlds.
SpeedyC2 (01-22-2020)
Old 01-16-2020, 04:34 PM
  #179
boomboomthump
boomboomthump's Avatar
OK, take our money.
Old 01-17-2020, 12:13 AM
  #180
djwpe
djwpe's Avatar
Interested.
Quick Reply: A Plug-and-Play, DIY-Installable 993 Immobilizer Defeat
