First 992.2 HD Matrix successfully activated!
Old May 30, 2025 | 03:51 PM
  #91
jperlinsky's Avatar
jperlinsky
Originally Posted by jperlinsky
Can anyone confirm that, after coding for matrix functionality, the parking lights are on whenever the car is in automatic headlight mode, even in bright sunshine when the main headlights aren’t activated? That doesn’t seem like typical behavior for US lights, but it’s what I’m experiencing now that the matrix lights are coded.
No. Those lights are on all the time.
Old May 30, 2025 | 04:55 PM
  #92
chiapet15's Avatar
chiapet15
@jperlinsky how bright is the light bar when it’s on during the daytime? Is it much brighter than at night? I am trying to see if this is a new operating mode or if it’s just the night time mode staying on all the time.
I actually really like the light bar and wouldn’t mind if it were on during the day, provided that it’s sufficiently bright
Old May 30, 2025 | 05:00 PM
  #93
jlegelis's Avatar
jlegelis
Coding the rear bar to be always on is well documented... search is your friend.
Old Jun 10, 2025 | 10:44 PM
  #94
rnlst_log's Avatar
rnlst_log
Unhappy
On .2 is no longer the case. Unfortunately!
Old Aug 6, 2025 | 02:35 AM
  #95
roozybeh's Avatar
roozybeh
5th Gear
Default Anyone able to help me do this in the Philadelphia area?
I’m new to this forum. Was wondering if anyone knows whom I can reach out to get this done on my US spec 992.2
Old Aug 6, 2025 | 02:47 AM
  #96
M3Inline6's Avatar
M3Inline6
Sure!
@718socal can help remotely.
Old Aug 6, 2025 | 03:24 AM
  #97
roozybeh's Avatar
roozybeh
5th Gear
Sure!
@718socal it still doesn’t allow me to send messages. Can you send me a message so I can get in touch with you?
Old Aug 6, 2025 | 03:56 AM
  #98
M3Inline6's Avatar
M3Inline6
I will text him for you.
Old Aug 6, 2025 | 04:42 AM
  #99
roozybeh's Avatar
roozybeh
5th Gear
Old Aug 6, 2025 | 02:27 PM
  #100
mallocfailure's Avatar
mallocfailure
Any other coders for the 992.2 HD Matrix lights? 718socal says he only does 992.1s.
Old Aug 6, 2025 | 02:39 PM
  #101
jlegelis's Avatar
jlegelis
@rnlst_log is the master
Old Aug 6, 2025 | 02:40 PM
  #102
M3Inline6's Avatar
M3Inline6
Yes he is!
Old Aug 6, 2025 | 05:45 PM
  #103
Espresso4S's Avatar
Espresso4S
Hopefully this is a reasonable thread to ask this question. I didn't want to start another one, but I suppose I could ...
I'm curious to know if anyone has had their HD matrix light coding undone at a service appt. I haven't seen a post about this so I'm thinking it hasn't happened to anyone here which probably means it's unlikely. I'm guessing that there are various subsystems in the car and if Porsche needs to apply a software fix for something in one subsystem, it probably doesn't affect others.
Note that I'm not asking for anyone's opinion on whether one should avoid enabling these lights because of some risk of the config being overwritten. All I'm asking is if someone knows that it has happened.
Old Aug 6, 2025 | 05:54 PM
  #104
Asiandude66's Avatar
Asiandude66
As a follow-up to the question above. How does one know if the 'unlock' got wiped out by the dealer after service?
Do you have to drive it at night and observe the light beams or is there an easier way to check?
Old Aug 6, 2025 | 05:57 PM
  #105
zanary's Avatar
zanary
I'm curious to know if anyone has had their HD matrix light coding undone at a service appt. I haven't seen a post about this so I'm thinking it hasn't happened to anyone here which probably means it's unlikely. I'm guessing that there are various subsystems in the car and if Porsche needs to apply a software fix for something in one subsystem, it probably doesn't affect others. Note that I'm not asking for anyone's opinion on whether one should avoid enabling these lights because of some risk of the config being overwritten. All I'm asking is if someone knows that it has happened.
If the control unit for the lights are replaced, then yes coding is reverted back to factory, but that is OK, because you can get one of the coders on RL to re-code for you.
Do you have to drive it at night and observe the light beams or is there an easier way to check? Thanks
You can tell when you turn on your car in the dark. Look for the startup pattern.
