Group Buy; JQ Werks & Madtrace Clubsport Magnetic Paddle Shifters for 992
#256
mattchow (05-19-2023)
#259
I have no other use for the O rings so why not use them as Porsche intended.
#260
Hopefully it’s ok to post this given the group buy has ended.
Here are the options for the OEM Weissach paddles ($1200-$1300):
https://www.ebay.com/itm/225551396723
https://www.ebay.com/itm/225581007621
…lastly, this requires you to buy the whole steering wheel, and add the Weissach paddles for $1500 (total price $5295):
https://www.suncoastparts.com/produc...t3rsalcsw.html
An alternative to JQ Werks, likely the same supplier, but with further adjustability (it appears) from Autotecknic ($495 + 10% discount offered):
https://autotecknic.com/products/aut...AaAgzWEALw_wcB
All in all, the JQ Werks are a steal at full price, so if you’re after the added engagement and F1 style experience of magnetic shifters, they make a great product at a fraction of the OE price.
#261
shrimp money (05-19-2023)
#262
I don't believe they are intended to be used with the new paddles. I measured all the dimensions with calipers and it appears the locating nubbin on the new paddles is intended to be the size of the old locator nubbin + orings.
reddsektor (05-19-2023)
#263
You’re correct. Perhaps I stated it in a confusing way; what I meant is that you can’t purchase just the paddles by themselves, you’re forced to select the wheel and then add Weissach as an additional option.
#264
#265
#266
I am about to install these. Hope it looks good with my yellow center tach.
One question - anybody happen to have a photo how the steering wheel looks with that yellow/green connector detached. I am reading if I dont do that right I may break the coil spring but have no visual how that looks with connector properly removed?
#267
Ok before I unscrew the steering wheel bolt, is there anything else I need to do? I disconnected the top yellow connector and the red one near the bottom. Does the yellow connector actually need to be disconnected from the black cables that actually feed into each side of it?
PS: Found this video. Looks keeping the green clip and pushing the yellow down unclips the yellow plug @ 4:25min ...is that how you all did it?
#268
how did you get that top yellow connector off? I removed the green clip and tried to pull it off but want budge. Tried to put a needle/flat had underneath, pulled with a plyer on the area where the green clip was...all to no avail. Worry I brake something...any ideas?
PS: Found this video. Looks keeping the green clip and pushing the yellow down unclips the yellow plug @ 4:25min ...is that how you all did it? https://youtu.be/JmAQ8vLXUuU
#269
I unlocked the green pin, texted my frustration to @22992 several times, took his advice, and put electrical tape around the teeth of a pair of channel locks, and used them to pull the green tab straight out. When I did this, the yellow connector unhooked from the black connector, and no one died.
#270
Yes, I might have damaged the green clip a little when things got violent.
