Disabling the rear spoiler
I'd like to know as well as I'd prefer the spoiler to stay down ALL the time...even at speed. You might have to pull the motors or disconnect the harness that powers it up and down. But I would think you would get all kinds of CEL and errors if you do that.
If you figure it out let us know!
On my 991.2 GTS, I bought the sport design wing and had to have it programmed. When that was being done, I think it had options for normal wing, sport design wing, glass roof or not (which changed how high the wing will go after 60mph) and OFF. I didnt exactly see all the options. But Im pretty sure its a PWIIS setting.
I so wish we had a version of bimmercode for Porche. It was so nice being able to use your iphone and tweak stuff like this for your BMW. We need that for Porsche!
Which wing? You would need to pull the fuse/motor, but obviously you'd have to tell the system as well - either through coding as mentioned or with a hardware loop which is what TechART provides in their kit.
Disabling the auto pop up function of the rear spoiler is only 1/2 the problem. The other issue is that the car will then give you an error when the vehicle exceeds 90 KPH.
The best solution is to find a way to program the system into thinking the rear spoiler is manually deployed “up” the whole time. That way there will be no fault messages generated .
Received 2,842 Likes
Wouldn't your insurance company take a dim view of standard aerodynamic aids being disabled if you have an accident? Different if Porsche provided a user configurable option to do so, but they don't so.....?
detansinn (03-04-2021)
Absolutely. The spoiler is an inherent part of the car's design and construction, understand law varies between countries but in Australia pretty sure disabling it would be seen as a modification which means zippo insurance cover unless declared on the policy and accepted by the underwriter.
If the US voided full coverage over exterior mods, then I doubt we would see so many decked out Hondas and Subarus running around with every aftermarket gizmo you can think of added to it.
Having once driven a 997 Carrera S, at speed, with the spoiler not operating properly, there's no way that would drive a 911 again without the active spoiler or a fixed rear wing. Quite simply, without the aero, it was not fun and it didn't feel safe. The aero is an important part of the package.
If you're disabling the active aero, you need a wing, ducktail, gurney flap... something.
The following 2 users liked this post by detansinn:
G650 (03-04-2021),
GuardsRed992 (05-03-2024)
Schwarz992C4S (03-05-2021)
Interesting. I could see American insurance NOT covering the cost of an aftermarket wing you didn't mention on your insurance policy. But I cant see them looking at a fixed wing to find a way out from covering the overall cost to fix the wrecked car to stock insurance policy levels. But I know nothing of how its done down south.
detansinn (03-05-2021)
Someone else did the same and just went to their dealer to disable the rear spoiler coding. Not sure how much or how long it took, but thats if youre willing to pay for it.
