Disabling the rear spoiler
PIWIS can code the spoiler as absent. It can also code multiple different heights fir different speeds.
Don't mess with the hardware alone, it will throw codes.
The following 2 users liked this post by John Mclane:
G650 (03-04-2021),
Schwarz992C4S (03-05-2021)
Interesting. I could see American insurance NOT covering the cost of an aftermarket wing you didn't mention on your insurance policy. But I cant see them looking at a fixed wing to find a way out from covering the overall cost to fix the wrecked car to stock insurance policy levels. But I know nothing of how its done down south.
If the US voided full coverage over exterior mods, then I doubt we would see so many decked out Hondas and Subarus running around with every aftermarket gizmo you can think of added to it.
AlexCeres (03-04-2021)
The 911 spoiler is not just aesthetic and is important for stability.
To be fair to the OP, he is adding an aftermarket wing...which most likely is bigger than our motorized spoilers and provide more downforce, hence, maybe more stability.
Tanqueray86 (03-05-2021)
Originally Posted by reddsektor
that argument wasn’t about the OP, it was about the other dude wanting to completely disable his stock active spoiler on purpose
When I mentioned earlier that you can disable it with PIWIS, that doesn't mean that's simple. Seeing first hand how it works, several modules are interconnected. I would not be surprised that the PSM takes or gives inputs to the spoiler. That alone opens a wide margin for errors to be thrown. So, while possible, coding with PIWIS is likely to be complicated . In al likelihood feasible but I would take it to someone that knows what they're doing (not always the dealer, actually seldom).
That all might be true. But I had a Subaru STI that had a big ol massive wing that I removed for the WRX version. I hit a curb avoiding a red light runner and my insurance rep didnt bat an eye at the smaller wing. I mean no offense to you or anyone else in here about this. But I think you guys are taking this to extremes. If you disable your wing and you wreck. No one is going to even know the wing didnt work. Unless it looks damaged, they will most likey assume its working fine and fix what they see wrong.
rouxeny (11-23-2021)
As proper downforce requires balance. Meaning bigger wing the back requires more downforce in the front. Otherwise, you get less stability.
OP: I think there's been plenty of feedback and side discussion. Maybe some pics of your car with the new spoiler will clear up concerns and questions! We're all interested in seeing your car!
Disabling the spoiler without a replacement wing is a bad idea as it comes. Beyond dangerous, it will throw a lot of errors.
I can't see why it would be overly complicated as there is already an OEM fixed wing option (Aerokit) and there are a number of aftermarket companies offering replacements such as TechArt and a few asian knock-offs.
Received 2,876 Likes
Tell that to the GT3 Touring. The regular GT3 got the big wing with big downforce while the touring got the small spoiler with a lot less downforce. Same front bumper and aero everywhere else.
Originally Posted by BlitzedTT
Perhaps there is a setting that says "Aerokit wing Installed"?
The front aero is changed, as well as its design.
Evo goes into further detail, but here's the punchline:
The removal of the fixed rear wing and relying on the retractable wing of the regular 911 Carrera and the small, additional Gurney flap on the trailing edge of the engine cover, means the car’s aero is changed significantly. It has resulted in a shorter front splitter being fitted and beneath the engine and behind the rear bumper there is a bespoke rear diffuser, although this differs compared to the one fitted to the 911 R.
The following 4 users liked this post by ipse dixit:
