ECU tuning
#31
I’m sorry, please don’t take offense. I’m sort of new to all of this. The idea that I should buy a car well over $100k, then take a piece out of it and send it overseas, then have it “reprogrammed”, then sent back to me to reinstall, all while losing my factory drivetrain warranty, sort of..........ya know. Defies common sense.
It sure would be better if I could drive it into a shop, get it worked on, and then drive it home right afterward.
Currently, if you are interested in a true flash, not a piggy back unit, you are in the same boat (to my knowledge) and the ECU must be bench flashed. We have taken the steps to bench flash the 992 ECU (safer alternative than a piggy back) as early as possible and are working on our OBD tool flash which should be ready in the first or second quarter of next year. Once our OBD flash is available, we can provide you with a flash tool so that you can flash the car back to stock file prior to taking it to the dealer (like past FVD OBD flashes).
@Rhonda@FVD thank you for continuing to help the Rennlist community. I want to share that there are those of us that appreciate what it takes to do what FVD does over many years. Local convenience is nice but I’d prioritize engineering know how and I’d trust FVD product 100%.
FVD Brombacher - USA
Contact me directly to get the latest FVD forum member discount!
Rhonda Roxburgh
+1-954-571-2050 x 1
rhonda.roxburgh@fvd.net
Want to learn more about us? Click here...
Rhonda Roxburgh
+1-954-571-2050 x 1
The following 6 users liked this post by Rhonda@FVD:
540gone (12-11-2020),
Auto Paint (12-28-2020),
bobblehead (12-11-2020),
NigelPlays (12-17-2020),
SBAD (12-12-2020),
and 1 others liked this post.
#32
#33
#34
I should have the write up finished up by the end of this week so it will be posted on our website.
- Payam@burgertuning.com
dgasmd (12-16-2020)
#35
FVD Software Upgrade - 992 C2 / C4 - 3.0 L - 460 Hp / 406 Tq - Send In ECU
#36
JB4 provides a plug and play solution that you can install in your own garage. It's easily removable and reportedly is not traceable once removed, so warranty would not be affected.
I recently installed a JB4 on my wife's 2020 C43 and stock 0-60 is advertised at 4.7sec.
Using a Dragy GPS tool after installing and with 93 octane the car sees 3.64 sec. 0-60 and 11.83 sec 1/4 mile.
Maybe not the best or the fastest but the car never left my garage for install and most importantly, I am impressed.
#37
#38
Yes it requires a bit of mechanical aptitude. It's may not be the fastest, but BANG for the buck and proven performance.... its great value IMO.
Personally, I want my ECU left untouched without any evidence of tampering.
#39
OK, so has anyone here actually done any ecu tune of any kind? Real and personal experience with it?
Also, when the eco is taken out and flashed, if one was to find a local place to do it, is that something that just takes a couple of hrs to do or this would definitely be a "leave it and we will call you in a few days when done" kind of job?
#40
Just chiming in to say it appears the best thing for the OP and some others’ desires on this thread to do is just chill & WAIT. What you want doesn’t exist right now.
Right now there aren’t any ODB flashes/tunes available that can be done on the 992 without having the ECU bench flashed. If you guys want something easy that can be done DIY in your garage or by a local tuning shop, then you gotta wait for someone to come out with a direct ODB flash a la Cobb Accessport.
Otherwise if you’re too impatient to wait the only 2 options available right now are:
1) Piggyback (JB4)
or
2) Send in ECU for bench flash.
Personally if I had to tune right now, I’d just send the ECU in to the pros who do this thing everyday and made the software vs. letting some small local indy tuning shop treat my new Porsche’s ECU like a guinea pig. I’m not sure what the obsession is here about having a local shop do the bench tune. I’d much rather send the ECU directly to the company making the tune. If anything goes wrong there’s no middle man to blame (Local tuner blaming Tuning Company & vice versa).
1) Piggyback (JB4)
or
The following 3 users liked this post by Rxpert:
#41
1) Piggyback (JB4)
or
1) Piggyback (JB4)
or
while I’ve dealt with many “far away” vendors, I have also learnt the value of the semi-local guy that I can go to and pound on the door so to speak. There is a certain live and personal accountability that comes from that old “I know where you live” kind of stuff. If I had the choice of going to a semi local guy/shop that does this and my type/car is something somewhat familiar and the “internet abstract big time company”, then I guess the answer is obvious. To me and most I’d like to think.
#42
1) Piggyback (JB4)
or
1) Piggyback (JB4)
or
You can even program the car from home yourself if you want to spend the $$ for Autotuner tool.
The DME is Bosch MG-1 and as far as tuning purposes is concerned, the DME is wide open as encryption has been resolved for quite some time.
Most of the more prominent calibration companies right now are working with their trusted tuning partners to program the calibration on the car remotely, which you cannot fault them for. The tuning industry is competitive-based so they are going to keep their cards as close to the chest as possible.
dgasmd (12-27-2020)
#43
Originally Posted by Cheshi143
My car was programmed by M-Enginering from the OBD-II port at their facility in Torrance and the DME was never removed from the car.
The car has been to the dealer numerous times. Due to one of the campaigns, the DME was updated. My tune guy re-flashed at no cost, using the new factory program as a base. No issues with warranty or even been asked if the car has a tune. The only time I was questioned about tuning was when the SA that deals with APR asked about the noise the car made (sport cats), more interested on what I had on and how I liked.
#44
Can you send me a link or number/name to the place where you dealt with it?? I’d appreciate it very much. Would love to contact them directly and have them answer all my dumb and entry level questions.
thanka again!
#45
Originally Posted by dgasmd
Ok, so you have me at “I love you too”😂😂😂😂
thanka again!
thanka again!
Alex Roy
info@petuned.com
PE Tuned
224.676.0756
