No-Drill Front License Plate Mount for all 992 (NOT a tow hook mount)
#46
Taking the mount on and off is super simple. It’s fine at higher speeds (90mph+) but I wouldn’t go through a touch carwash with it as it could be dislocated. It’s not the bracket’s fault, just the relatively thin polyurethane bumper cover material that is the mounting surface. On street legal speeds +, you are fine. If you’re going to the track, probably fine too, but you’re probably removing the bracket and stowing in the frunk anyway ...
#47
Maybe others have mentioned this before....... I have the standard factory plastic front plate mount for my 2021 C2S that came with the car when I bought it. When you hold it in place with your hand or tape to the front bumper in its specified mounting spot, there are two small plastic tabs on the bottom of the plastic mount that extend backwards about 1-2 inches. This is similar to the license plate mount on my old 997. So, same as the 997 mount, I used a small drill, and drilled UP through those two small tabs, into the BOTTOM of the bumper. The holes are impossible to see unless you lay down on the ground on your back and look for them. Then, you take two small self tapping screws and screw them UP through the tabs and voila your license plate mount is mounted, and reasonably secure - at least enough to drive it on the highway, etc. I live in Virginia, where front plates are required. So what I did is already attach the license plate to the plastic mount, and I carry the mounted license plate in the frunk along with a small baggy with two screws and a small screwdriver and a towel. If I get pulled over, I tell the officer I can fix it now if he will give me 5 minutes. I pull out the towel, lay it on the ground, lay on my back, screw on the mounted plate, thank the officer for his patience, and then motor on my way. I pull the plate off when I get him and toss in back into the frunk. All of these expensive and fancy mounts are not needed, and this way the mounted plate does not interfere with the ACC or the parking sensors or anything else. Sometimes the simplest solutions are the best. Good luck, be careful out there and remember YMMV.
grg1 (05-08-2023)
#48
#49
Avoiding holes and screws are the very core ethos of our designs. Yes simpler solutions are available to those willing to pull out a drill but that level of compromise is just unacceptable to our customer base. Fancy engineered and personally adjustable mounts are not for everyone and that's ok
peterdouglas (03-23-2021)
#51
We just received a message from a customer telling us that he was driving around last week without his front license plate and got pulled over. A quick 'sorry officer I just washed the car and forgot to put it back on' and 5 second install later and he was let go with a verbal warning.
Even if you hate front plates and don't want to drive with them on, keeping one of our mounts in the frunk is a great way of getting out of a ticket.
3rdpedal (03-19-2021)
#53
#54
Austin111 (03-19-2021)
The following 2 users liked this post by Carbonio:
peterdouglas (03-23-2021),
SonofaTarga (03-19-2021)
#56
Temporary legal alternatives
The Carbonio and StoNShow devices look great, although it does not seem any of the currently available devices would work for my 992TTS (which also has the Sport Design package).
HOWEVER, many states have a law along these lines, which would (temporarily) allow a no-drill decal or adhesive plate - with number only):
Connecticut Code Title 14, Ch. 246, Sec 14-18(c):
Connecticut General Statutes § 14-18 (2019) - Display of number plates and stickers. Issuance of sample number plates. Return of number plates to commissioner. :: Title 14, Chapter 246 - Motor Vehicles :: 2019 Connecticut General Statutes :: US Codes and Statutes :: US Law :: Justia
#57
Cheers and keep driving!
Ross
#58
#60
Here are some photos of the low-tech solution I have successfully used on my 2021 911 and on my older 2007 911. This is not rocket science folks. As long as you are careful and can drill a straight hole with a tiny 1/16 inch drill bit you are in business..... Honestly, I think the Carbonio is interesting, if perhaps a bit overengineered. I prefer to keep things simple. For those of you who (a) don't have ACC and (b) live in jurisdictions where you must have the front plate mounted, then perhaps Carbonio is a good solution for you. Personally I HATE front license plates on any of my cars. I'm willing to take the risk of getting pulled over and hoping the cop is sufficiently patient to let me screw the plate on and then be on my way with a warning. Anyways, like I said, this isn't a difficult problem to solve. Good luck.
Cheers.
Ross
Cheers.
Ross
