Just finished this install on my 2024 Targa 4S! Thanks to all that contributed information. Was very easy to do with the help of this thread. Only thing I didn’t do was run wire under #2 housing. Just exited wire between #1and #2 at the seam, and then used zip tie to keep concealed and out of the way! Overall a really clean and easy job!
I wonder if it’s possible to remove plastic panel number 2 without removing part 1first?
I want to change it becuase it’s melted from tinted the window.
thank you
You don't need to remove that piece. Get a trim removal tool or something that won't scratch things and pry the piece downward just enough to feed the wire through.
I admit I originally just did a search for “preparation” and came up with nothing. Now that I went back, I only found a couple posts from a couple years ago, merely speculating about the new option.
I’m wondering if anyone with the option has seen or noticed any change in the process outlined here.
I have a complete write up of how to use the OEM connector that comes with the factory installed prewiring and the connector u need to purchase to make the connection.
Just a suggestion be a little less specific when running your search terms to get more results
Did the install for the prewire. Mostly easy but not much room to stuff the wires. Me being ****, I bent the metal clip on the dome, the one you slide the credit card to unhook. Is that an orderable part? I bent it back and it works fine but it annoys me that it's a little crooked.
