DIY - Wiring overhead console for Radar etc.
#122
Yes Blendmount with the M2 attachment. I also used the Blendmount mount wire tap kit with the multiple size pins.
xs2k (10-11-2022)
#125
Success!
Hey guys. Followed the directions in this thread and it worked like a freaking charm. You guys are the best!
FYI, I was able to use my fingernail to pry open the perforated panel which seems safer than a screwdriver to use. Also I used a long zip-tie to snake the wire through behind the mirror, just used some electrical tape to attach the wire and pull it back through.
#126
Nice 6TT!
I stuffed my V1 wire in between the A-pillar and windshield, and wired it to the fusebox.
Curious how you like the new model! I have my old one so dialed in, I almost don't want to mess with it (X and K bands disabled solves nearly all of the issues with the old model, IMHO).
#128
great instructions, did mine in 20 minutes.
#130
Blue Connector Broke - Part?
Referencing the picture below, when I pushed the blue connector back into it's holder, the left part of the blue connector snapped and now my dimming doesn't work due to the connection now being broken.
I am now trying to determine the part number to order it from Porsche. My dealership and I have tried a few wiring harnesses but none of them are coming up / the right ones when we order them.
Welcome any help in confirming...alternatively, I am considering buying an aftermarket waterproof connector and doing it myself. Thank you.
Vicbastige (03-24-2023)
#133
Thank you very much @audi4t!
So, what you are saying is take the 3 wires on the left which is the part of the connector that's broken and then somehow connect it into the Dongar connector? Apologies for the "dumb" question, just trying to track what you are proposing!
#134
Dongar Technologies Dashcam Power Adapter (3-pin Porsche, Keyway 1) https://a.co/d/biEgbAU
The Dongar adapter has a male and female 3 pin adapter u can cut off which one u need and splice it inline to replace your broken connector
RollerCam (03-24-2023)
