The Porsche 992 Aftermarket Wheel Thread
#316
Basic Sponsor
[size=3]HRE will make any offset that the customers wants as long as the aluminum forgings can actually achieve the offset. With 1-piece wheels this sometimes poses a problem but not on their multi-piece wheels.[/size=3]
The HRE R101 Lightweight's use a very specific lightweight aluminum forging that has limitations on the offsets that can be used. If the offset that you want happens to be outside of this offset range, then the wheel automatically has to use a different aluminum forging which is not as lightweight and therefore is no longer an R101 Lightweight. Essentially turning it into a P101 which is lightweight in it's own right just now as extreme as the R101LW's.
I really don't understand offsets and wheels. I guess it depends on the wheel? Yours rear offset is about 16mm off from @tourenwagen and it llooks about the same. So confused. Someone help me out here and explain it to me pls.
Width, offsets, and ride height all work in unison with each other. If car A and B have the same wheel width & offset but car A has factory ride height and car B has lowered ride height, then the wheels/tires on both cars will have different degrees of "flushness". That it what a lot of people ordering wheels for customers don't understand. We take that into account when we order wheels for every single client and that's how we get everything nailed spot-on.
Wheels Boutique // 786 249 0127 // Sales@wheelsboutique.com
Follow us on YouTube: www.youtube.com/user/WheelsBoutique
Largest Dealer In The World for HRE Wheels, ANRKY Wheels, Vorsteiner Wheels & Aero, Akrapovic Exhaust, & iPE Exhaust
BBS, Forgeline, & TechArt Premium Dealer
Brembo / Rotiform / KW / H&R / Novitec / Brabus / Mansory and tons more...
#319
Aston Forged GT3 wheels en route
Idea came from seeing this Artic Grey GT4RS a few months back...
Slightly increased offset compared with stock, 20x9j et48 and 21x11.5j et60, en route to me here in the UK from ASton Forged in Taiwan.
Last edited by Tyrell's Prodigy; 03-21-2023 at 06:55 PM. Reason: additional images
The following 3 users liked this post by Tyrell's Prodigy:
The following 3 users liked this post by Bezlar:
#321
Basic Sponsor
For those who don't want to wait for a new set of wheels to be made, I have the following performance wheelsets in-stock. I can send photos and more information to those interested in anything from the list: David@WheelsBooutique.com
ANRKY AN10's in Brushed Clear for 992 GT3
HRE 522M in Frozen Brushed Gold for 992 GT3
ANRKY S1-X1's in Two-Tone Brushed Clear with Gloss Black for 992 Turbo / Turbo S / GTS (with Centerlock)
HRE P104SC in Gloss Black for 992 Turbo / Turbo S / GTS (with Centerlock)
HRE 522M in Satin Silver for 992 Turbo / Turbo S / GTS (with Centerlock)
AL13 C020-109R in Polished Clear for 992 Turbo / Turbo S / GTS (with Centerlock)
HRE S107SC in Brushed Clear for 992 Carrera / Carrera S / Carrera 4 / Carrera 4S / GTS (with 5-Lug bolt pattern)
HRE P104 in Brushed Champagne for 992 Carrera / Carrera S / Carrera 4 / Carrera 4S / GTS (with 5-Lug bolt pattern)
ANRKY S3-X1 in Two-Tone Satin Brushed Clear with Satin Brushed Gold for 992 Carrera / Carrera S / Carrera 4 / Carrera 4S / GTS (with 5-Lug bolt pattern)
tourenwagen (03-30-2023)
#323
What's the weight on this set? I assume 21/22? They are very similar to the set I have but probably lighter...very nice.
The following 4 users liked this post by WheelsB:
#326
Two questions that would help out immensly:
Will two different wheels with the same offsets sit exactly the same off the rotor? For example, will a HRE 300FMR(two-piece) and a HRE P101(monoblock) both 20x8.5 ET45 sit exactly the same (inward and outward) if mounted on the same car?
Will a centerlock version and a 5 lug version of the same wheel sit exactly the same? For example, will a HRE P101 in centerlock and a HRE P101 in 5 lug, both 20x8.5 ET45 sit exactly the same (inward and outward) if mounted on the same car?
Thanks.
Thanks.
#327
Thanks.
Thanks.
#328
EDIT: Maybe it does answer my question as there's no input variable for wheel type?
#330
