992 GT3 and GT2RS Forum 2019-Current
S/T Suspension Programming - GT3 update??
Old 08-28-2024, 08:34 PM
  #391
catdog2
catdog2's Avatar
Originally Posted by Modern Growl
Perhaps I missed it but how does this make the car corner and handle, that is not in straight line comfort ?
The car handles very well and is less bouncy and jittery, better damped, corners extremely well and less disturbed by mid corner bumps and road irregularities...
The following 3 users liked this post by catdog2:
Diablo Dude (08-29-2024), EMdoc (08-28-2024), Jbravo23 (08-28-2024)
Old 08-28-2024, 10:24 PM
  #392
Jbravo23
Jbravo23's Avatar
Received 1,801 Likes on 726 Posts
Just one man’s opinion but having crossed 11k miles i can say I believe the car handles better than before. This is based on road driving only.
There’s some roads by me that I have driven now for years and I am always playful when taking a few of the turns aka I like to let the back come out and I’ve tried it a few times now same rpm same speed same everything and the instead of cutting loose it just dug in. I was pretty amazed.
RWS was very noticeable prior (was never a big fan of it). It now seems to mask it a bit.
The car is so good now I barely post. I just come to see what @f4bones has up his sleeve 😬
The following 3 users liked this post by Jbravo23:
cyn (08-30-2024), Diablo Dude (08-29-2024), EMdoc (08-28-2024)
Old 08-28-2024, 10:38 PM
  #393
EMdoc
EMdoc's Avatar
Ditto 100%!
Old 08-29-2024, 01:36 AM
  #394
Rmas99
Rmas99's Avatar
I have exactly the same opinion. Just one word: WOW
Jbravo23 (08-29-2024)
Old 08-29-2024, 05:31 AM
  #395
f4bones
f4bones's Avatar
Received 1,395 Likes on 536 Posts
sneak peak . .
The following 7 users liked this post by f4bones:
718socal (08-29-2024), dixonk (08-29-2024), EMdoc (08-29-2024), gixxer_kidd (08-29-2024), Jbravo23 (08-29-2024), Mech33 (08-29-2024), tivs31 (09-01-2024) and 2 others liked this post. (Show less...)
Old 08-29-2024, 11:05 AM
  #396
Mech33
Mech33's Avatar
Looks promising! Warning says function only available in Race driving mode, but display looks like you are already in Race driving mode…?
Old 08-29-2024, 11:34 AM
  #397
ipse dixit
ipse dixit's Avatar
Received 12,124 Likes on 5,271 Posts
For those who just want a purely analog gauge cluster and think digital UIs are the bane of all car enthusiasts' existences, this, and I mean this specifically, is exactly why you are wrong.
Well done @f4bones
The following 3 users liked this post by ipse dixit:
AlexCeres (08-29-2024), dixonk (08-29-2024), EMdoc (08-29-2024)
Old 08-29-2024, 01:43 PM
  #398
newenegue
newenegue's Avatar
Out of curiosity, what tire pressures is everyone running with the S/T suspension coding? Is the S/T damping just as good on the OEM recommended tire pressures?
Old 08-29-2024, 01:44 PM
  #399
f4bones
f4bones's Avatar
Up very late with Mars trying to sort through this, but I think we figured it out. Had to do a long firmware upgrade on the instrument panel . . there are now 3 modes: normal, sport and track, just like GT3, and you can only vary the settings in track mode . . . I will go test drive this morning, but looking very promising!
718socal (08-29-2024), catdog2 (08-29-2024), dixonk (08-29-2024), EMdoc (08-29-2024), Mech33 (08-29-2024), rnlst_log (08-29-2024), TOporschefan (09-01-2024) and 2 others liked this post. (Show less...)
Old 08-29-2024, 02:01 PM
  #400
EMdoc
EMdoc's Avatar
Impressive and good luck!
as for the post above, I’m still running track settings for tire pressure. 28 F/30 R. Would be curious to compare with going back to stock pressure. Might try it soon.
The following 2 users liked this post by EMdoc:
milban (08-29-2024), newenegue (08-29-2024)
Old 08-29-2024, 04:43 PM
  #401
f4bones
f4bones's Avatar
OK - just back from a short drive - everything seems to be working! There is SO much adjustability with the RS system - kind of overwhelming. I concentrated mostly on the dampening, and pretty dramatic difference between full soft (-4) to full hard (+4) - not quite sure where the happy spot is. After I confirmed it is actually working, I set the suspension to full soft, and seemed very similar to the S/T settings, but really can't opine at this point.
I guess the take away is if you want to fiddle with the system, the RS configuration allows you almost INFINITE fiddling possibilities . . certainly would be fun for track. It seems that the only hardware upgrade required is the RS steering wheel w/ controls - we were able to update the other modules firmware to accept coding. It's a LOT more involved than the S/T update, but definitely doable and pretty nifty. One interesting cool feature is that in track mode (the only mode where you can adjust the settings), you have the option to automatically configure for track tire pressure, and you get a small icon of a race way with an R showing you have selected TRACK tire pressures . . .
Still a bit of work to do as we haven't programmed the PCM and the configuration options in the PCM menu don't quite match the options you get when you press the center button of the mode button. . . the center button of the mode display give you more options to configure.
The following 10 users liked this post by f4bones:
718socal (08-29-2024), aarodynamics (09-23-2024), catdog2 (08-29-2024), Diablo Dude (08-29-2024), dixonk (08-29-2024), EMdoc (08-29-2024), Jbravo23 (08-29-2024), sensei_tts (08-29-2024), TOporschefan (09-01-2024), Tour the Ring (08-29-2024) and 5 others liked this post. (Show less...)
Old 08-29-2024, 07:30 PM
  #402
Shogunade
Shogunade's Avatar
Received 2,195 Likes on 1,211 Posts
Should name the gt3 subforum the f4bones and rnlst_log show. Only thing worthwhile going on here.
The following 6 users liked this post by Shogunade:
aarodynamics (09-23-2024), catdog2 (08-29-2024), dixonk (08-29-2024), EMdoc (08-29-2024), michaeldorian (09-13-2024), TOporschefan (09-01-2024) and 1 others liked this post. (Show less...)
Old 08-29-2024, 07:38 PM
  #403
catdog2
catdog2's Avatar
Wow you guys did it!! Great job !
are you able to adjust the traction control/ptv?
Old 08-29-2024, 08:01 PM
  #404
catdog2
catdog2's Avatar
Del
Old 08-29-2024, 09:55 PM
  #405
Chris C.
Chris C.'s Avatar
Has anyone driven an ST and a modified 992 GT3 back to back (or close enough)? I am curious if the mod is how a real ST drives and handles....
We know there are some hardware differences on the 2 cars (steering anyway) do we know they have the same roll bar thickness and settings?
The following 2 users liked this post by Chris C.:
Diablo Dude (08-29-2024), sensei_tts (08-30-2024)
Quick Reply: S/T Suspension Programming - GT3 update??
