Delays due to PCCB
#151
For what it is worth .... last year the Porsche factory shut down was from 31 July 2021 to 23 August 2021. Not precisely sure when the 2022 shut down will be but I am highly confident that MY22 cars will be built up until the summer shut down begins..
#152
Didn’t the shutdown get extended into Sept last year?
#154
My ‘22 TTS was PTS and stayed V110 for a month before being scheduled. Begins production 8 July, completed 15 July. It’s clearly a ‘22 model. Might it get delayed, yes. If so might it become a ‘23, I guess so.
Just some more general info for you. Good luck.
#155
#156
My build date is 7/15.
TukeeGatorGT3 (03-05-2022)
#157
Do you know when you entered your build specs originally?
Is your car PTS also?
My car's build was done Jan 11th. It was built back in November originally but final build was entered Jan 11th with correct specs.
#158
I have a feeling our cars will be assembly line and ship mates. My order was created 11/15 and I spec'ed my final build early Jan. PTS and Cxx. Cxx was just approved 2/14. TYD went online soon after but dates have already started moving around. Currently scheduled to start production 7/22 and end 8/26, which seems to not make sense since factory is usually closed during that time. So, I'm sure it's bound to keep changing. My guess is, it'll end up in production in the fall as a MY23.
#159
I am a 2022 MY Touring, 7/10 production complete (as of today) per TYD, which I have been told is inaccurate for PTS cars as they are managed in a separate system with no interface, I am showing 1LX on the build.
#162
Yes, I had my order signed and booked (quite fresh) but they have called me from the dealer and said that I need to cancel PCCB if I would like the order to be processed. I have no other option so go for the steel ones. Maybe I will change them later but hoping that the situation will change and be back in the line is not the solution.
#163
As of yet, I have not been asked to change. If they do I will just run Surface Transforms discs. Better disc anyway.
jimdillard (03-15-2022)
#164
Ok thanks for the information you have a new order and I will guess a mid year production timeframe? Next wondering what is the situation for near at hand builds scheduled here in March-April timeframe. Several of us suspect our build date has been delayed due to part supply problems and the PCCB’s are a leading suspect cause. My car has been delayed three times but no communication about the particulars. No communication about brakes or issues.
#165
Expected may production here. Was asked to change my order to Iron rotors.
SA said Porsche has no timeframe on when PCCB would be back...
