Manual 991 owners, Are there many of us?
Old 10-26-2016, 08:49 PM
  #196
Needsdecaf
Needsdecaf's Avatar
Received 2,608 Likes on 1,620 Posts
Originally Posted by jimbo1111
Actually it is different. Here the Porsche documentation to prove so. Paragraph 3
Part numbers on Carrera S and GTS are the same.
Old 10-26-2016, 11:43 PM
  #197
jimbo1111
jimbo1111's Avatar
Shifter parts and transmission are two totally different aspects. From what I've heard the transmissions are where the change occurred.
Old 10-27-2016, 12:32 AM
  #198
Suitcase
Suitcase's Avatar
Default DD
'14 C4 Coupe MT. What a privilege to drive a 911 every day. Purchased CPO with 14k. Love it.
Old 10-27-2016, 12:49 AM
  #199
silvertige
silvertige's Avatar
Um... need more evidence than that. I'm not convinced that Porsche would do what you're saying for the GTS alone and not the rest of the manual Carreras. That just doesn't make sense considering what the GTS is.
Old 10-27-2016, 12:50 AM
  #200
silvertige
silvertige's Avatar
I think you're going to have to post the part number for the GTS and S transmissions as well to finally settle the matter...
Old 10-27-2016, 09:30 AM
  #201
jimbo1111
jimbo1111's Avatar
I don't see why an official document doesn't do it for you. Changes always occur over time and the GTS has the same transmission as the 991.2 except for gearing which has bin lengthened to make use of the broader torque curve. I haven't seen a detailed parts list of the inter workings and I don't believe we will for some time because. Porsche's main supplier of transmissions, ZF Friedrichshafen AG has preparatory and infringement rights to those parts. I'm sure there competition would love to know exactly the very same details you seek.
Old 10-27-2016, 10:28 AM
  #202
Needsdecaf
Needsdecaf's Avatar
Yet the document you produced said "gear shifting unit", not transmission. Two very different things.
The only thing I can think of is that they made a running change to the part for ALL the cars with the introduction of the GTS, but didn't change the part number. This does happen...if it's a minor change, they may not change the part number.
But it still has the same shifter as the S for the same year.
Old 10-27-2016, 12:00 PM
  #203
jimbo1111
jimbo1111's Avatar
I just checked and there are no GTS shifter parts listed under GTS manual transmission on the website you posted above.
Old 10-27-2016, 05:10 PM
  #204
jimbo1111
jimbo1111's Avatar
OK, punched in my vin number and it seems that the transmission has bin revised. Here is the snap shot. 01 to 02 revision. What I find interesting is that this transmission can be used in a GT3 by the dialog box on the lower left. Interesting.
Old 10-27-2016, 05:31 PM
  #205
Needsdecaf
Needsdecaf's Avatar
The two screenshots above are from when you select a 2016 GTS and then navigate to the page with the shifter on it (body, console) and a 2016 Carrera S respectively. There is no GTS part specifically; you select your year, model and trim and then it shows you applicable parts.
It is also the same part number as my 2013 Carrera S.
Old 10-27-2016, 05:38 PM
  #206
jimbo1111
jimbo1111's Avatar
When selecting 2016 gts there is no selection for transmission. So I don't know where your getting the information. It's inaccurate. I had to look up the parts via vin number.
Old 10-28-2016, 12:12 AM
  #207
Needsdecaf
Needsdecaf's Avatar
It's not under transmission. There is no section for transmission, as they do not sell the transmission. I'm not talking about the transmissions, I'm talking about the shifters.
Look at body / console and it will be there. http://www.sunsetporscheparts.com/au...t/console-scat
Old 10-28-2016, 12:16 AM
  #208
Needsdecaf
Needsdecaf's Avatar
You can see it better here.
Old 10-28-2016, 09:33 AM
  #209
jimbo1111
jimbo1111's Avatar
So you just proved that there is an updated shifter. Part 991-424-010-01 is an update to the 991-424-010-00 and I proved to you that the GTS has a different transmission than an S since you need a vin number to access the part. I'm glad we finally got to the bottom of the mystery. EDIT: checked again with vin number and the Transmission is no longer available. I'm going to call the parts department at the dealer and get a good part number as the Sunset website isn't listing the transmission part.
Old 11-11-2016, 04:21 PM
  #210
jimbo1111
jimbo1111's Avatar
Finally got around to calling the parts manager over at my dealer. Transmission part number for the 7 speed GTS is as follows. G90.100.i20.
If someone with a 7 speed S can follow up and get a transmission part number. We may be able to finally put this to bed.
Quick Reply: Manual 991 owners, Are there many of us?
