What do all those console buttons do?
There are so many 991 performance and safety enhancement systems designed by the Porsche engineers, it boggles the mind. After searching around, I'd discovered tons of separate posts but not one that covered them all. So, I've put together a comprehensive list of the features that are controlled by each of the center console buttons that may be useful as a sticky for reference purposes. Please provide comments and omissions and I will update.
-Steve
PSE (if equipped) & Sound symposer activated
PDCC (if equipped) response is increased
Throttle response increased when above 25mph or, after quickly depressing or releasing the accelerator
PDK (if equipped) up-shift points delayed & down-shift points increased with shift times reduced
Dynamic Engine Mounts (if Sports Chrono equipped) firmness increased
Oil cooler valve opens
Coasting & Auto Stop (if PDK equipped) Disabled
(if Sport Chrono equipped)
Coasting & Auto Stop (if PDK equipped) disabled
Throttle response further increased
Dynamic Engine Mounts (if Sports Chrono equipped) are locked
PASM (if equipped) is set to firmest setting
PTV differential locking increased
RPM limiter is harder
PSM/ABS less intrusive
Launch Control enabled (if PDK equipped)
7th gear is disabled
Dynamic cornering lights are more responsive
(if PASM equipped)
Damper firmness activated
NOTE: May be disengaged after activated by the Sport or Sports Plus buttons
PSM (Porsche Stability Management) & ASR (Anti Slip control) are disabled (for extra traction in snow or faster track times)
NOTE: ABS (Anti-Lock Braking) & ABD (Auto Brake Differential) remain on
Spoiler control. To raise press one time
To lower less than 9mph, hold the button until the light goes out
To lower between 9pmp and 75mph, press one time
NOTE: automatically activated at 75mph and lowered below 50mph
(if sports exhaust equipped)
Opens the sport exhaust & sound symposer
Auto Shutoff Disable
NOTE: Auto Shutoff is also disabled if: battery needs charging, climate control system demands, engine temperature demands
-Steve
(if PASM equipped)
The following 2 users liked this post by Stevie:
bb964 (07-28-2021),
NigelPlays (02-19-2020)
Both PDCC and dynamic motor mounts are always active. Like the other systems- throttle, PASM, etc- they are "on" but have a range of aggressiveness, responsiveness, whatever you want to call it. The ranges overlap a great deal. Nothing ever really "locks" it just goes to increasingly aggressive mapping.
Does steering ever change? News to me. I'm guessing this refers to effects of improved responsiveness of PDCC, PASM, PTV, etc.
Thanks for the feedback,
-Steve
Does anyone know if pushing the PSE without the Sport opens the Sound Symposer? My own aural impression is that it appears the Sound Symposer stays closed. But I can't rule out the more aggressive sound of sport setting being a result of the throttle mapping.
Sent from my iPhone using Rennlist
I stand corrected on this point. They are always on call. It is the programmed threshold that is effected by these controls.
In the 991 Porsche Identity brochure (http://files3.porsche.com/filestore....3-001a64c55f5c), more direct steering is a benefit of PDCC, PASM etc, and not a change in the steering ratio, as you propose? If true then it should appear after the word "therefore". Right? ,
-Steve
-Steve
