Licence Plate on front bumper
#91
I have a 2018 GTS w/zunnsport grill and am putting the Skene short ones on. Only, concern is that the screws seem awful small, has anyone had a problem with the plate falling off?
#93
It is. bkrantz posted what he did to make it on RL some time ago.
#94
I bought the tow hook mounting device, but I only use it when I drive in problematic areas where the chances of being ticketed are high. It takes less than a minute to mount the plate.
#96
Here's the thread to bkrantz's custom plate thread, for those interested: https://rennlist.com/forums/991/9861...e-bracket.html
#97
Here are some photos of the Skene front license plate bracket installation. The green dots were placed on there just to help orient the brackets. You will also notice some extra clear adhesive bumpers attached at some possible touch points. Those were not in the kit, although two were supplied. Follow the video instructions, measure twice, drill once. It's super easy:
#98
I just installed Skene brackets as well on my '19 GTS. The extra short ones worked perfect. Yes, measure twice and drill once. I used a small manual drill that I purchased online. Worked like a champ.
#101
Thanks very much
#104
The Skene works great, and you don't have to worry about being stopped on your way home from dinner after sharing a special bottle of wine with your wife. Be careful,avoid a stop if possible.
#105
I have a 2019 C2 on order. In communication with the folks at Skene they seem unsure as to whether their mount will work because of horizontal black grille on front of car. Looks like you have same grille and it works for you? Which Skene mount did you get? What drill did you use and where did you get it?
Thanks very much
Thanks very much
