991S Not Starting
#106
My turn. Not a spirited drive at all, never left our city limits. Highest speed limit was 45. We went looking for a new bedroom set. 1 store, about 6 miles from our house. We were in there for about an hour, came out, it started and died. After the 6th try, I called roadside assistance.
Waiting for the tow truck will have to be a rant thread on it's own, but after nearly 2 hours I drove it on the flatbed. We'll see what the dealer has to say tomorrow.
#109
My service adviser said it's the spacer issue. Also, that there was a service bulletin issued for cars built after Sept 9th. That doesn't make any sense. I would hope by then, they had the problem sorted out.
The only code they found was for trying to start it without the key. I know that didn't happen. The key was in my pocket the whole time.
#112
Yes, this happened to my C4S with PDK today. Drove 10 minutes down to the post office, got back in the car 5 minutes later and it did to want to start. Ran the starter engine 3-4 times for 5 seconds each, no ignition. Then it finally started, only to die after 3 seconds with every possible symbol lightning up in the instrument cluster. Checked the petrol, the oil, the battery, all good. No error messages in PCM.
While this happened I was unable to disengage the parking brake.
Then after another 1-2 tries it fired up again, I put it in Sport mode and drove home with no issue.
Never happened before.
