991S Not Starting
So tonight I took the 991S out for a "spirited" drive (roughly 15 miles, up to 6500-7k rpm). Parked it at the destination, it sat for about 2.5 hours. The ambient temp fell from about 65 to 45 (dew everywhere).
Got back in the car, it would turn over no problem but it wouldn't fire. I tried multiple times (7x), but it wouldn't give. So I called roadside to have it towed to my dealer. While waiting for the flatbed I went out (20 min later) to try again and it fired up. Cancelled the tow and went home.
Has anyone had this happen before?
Thoughts / advice would be appreciated.
I plan on having it examined by my dealer tomorrow. I will post if anything comes of it.
Hi I got the exact same problem. It wont' start after a spirited drive (perhaps?) I couldn't constantly reproduce mine. But my car will be able to start after like 15-20mins. And this has happened to me like freaking 10times already over 1.5 month period. I got the car in March.
I am so disappointed with Porsche.Brought it into dealer 3x already and they couldn't reproduce it. They couldn't find any fault codes in the system. No mechanical issue either. Now they are ordering some parts (crank sensor or something) to replace it and let me try to see if my issue would go away.
I'd like to have this info in hand. That's EXACTLY the problem you described. This is the first time. It also doesn't usually get taken above 6k on the tach.
I will have the service manager at Paul Miller drive it hard with me tomorrow.
did it crank though or not even that?
Just once...mine took a long crank and didn't start the first time..but immediately did the 2nd time. The workshop mgr said it's probably the fuel...I always use chevron or shell... from that time I only use shell...(not sure entirely if it's the fuel issue but hey they put a lot of sh** in the fuel in California...)
I picked a GT3 up at the factory. I drove it to the Stelvio Pass. When I was negotiating the switchback I had to slow and stop on one of the turns. The car stalled. It took 5-6 attempts to get it started again and then the engine light went on. When I got to St. Moritz the Porsche dealership was closed. I waited for the next morning to bring it in. It started immediately in the morning and the engine light was off. Never had another problem in the time I owned the car. When the car was checked at the dealership in the States, they found no error codes. I think it was a CO2 sensor problem that corrected itself after I got it started. The funny thing is you think that the "big brother" computers in the car would have a record of all untoward behavior of the car but it doesn't. It can be very frustrating.
Let's hope you don't have any more "episodes". Good luck.
Stelvio pass must have been sweet. Hopefully you were going up on the switchbacks?
I have a service appointment for end of month. They couldn't find anything in terms of codes.
Once some of the others get the new crank sensor, could you please post the part number if it is on your service record when you pick up the car?
Thanks.
