Fun Facts about the 991 (please contribute)
Old 06-12-2019 | 04:27 PM
  #286
scottlma's Avatar
scottlma
Originally Posted by AzCoronaDog
When you turn the car off (and open the door I think), the clock in the Sport Chrono goes to 12:00 and the second hand stops at the top. When you unlock the driver's side door, some dash lights come on, like the odometer, and even before the key is turned, the clock eventually spins to the correct time and the second hand starts moving.
The Porsche engineers must be very punctual - the time can show in 4 places at once with Sport Chrono: the digital time in the chrono, the analog time in the chrono, on the PCM, and in the multifunction display in the dash!
When I bought my '11 Cayenne S with the Compass, there were zero clocks available in the car. A couple of PCM version upgrades later suddenly found one on main display and as option in LCD dash dial. Porsche must have gotten enough complaints to make the changes and overreacted a bit on 991.
Old 06-12-2019 | 04:53 PM
  #287
Rodolph Dandan's Avatar
Rodolph Dandan
Love those tips, never knew a lot of them!
Old 06-12-2019 | 09:48 PM
  #288
Tecni's Avatar
Tecni
I tired pulling both paddles to see if It would go into neutral and nothing...
Old 06-13-2019 | 06:01 PM
  #289
PCA1983's Avatar
PCA1983
My recollection is it won't work unless in Sport or Sport+ then to get back in gear, you have to still be rolling and pull the right paddle or pull the gear shift back for an upshift to 1st gear. If not rolling, you have to press brake pedal while pulling for an upshift to get into 1st gear.
Old 06-13-2019 | 06:14 PM
  #290
ericmeds's Avatar
ericmeds
Not necessarily - you can shift from N to 1st and so on but you need to be going over about 5mph otherwise you'll have to roll to a stop in N, apply brake then go to 1st.
Old 06-17-2019 | 10:43 PM
  #291
Z00mie's Avatar
Z00mie
On 991.1 coupes the OEM sunshade (in vinyl case) fits behind the rear seat backs perfectly, fully out of the way and is easy to retrieve!
Old 06-17-2019 | 10:46 PM
  #292
shammerman's Avatar
shammerman
Hmm... mine does.
Old 06-18-2019 | 03:04 PM
  #293
wareaglescott's Avatar
wareaglescott
Funny you mention this as I bought one when I got my car. Rarely leave it out in the sun and forgot it was back there until reading this!! I does fit perfectly.
Old 06-18-2019 | 03:40 PM
  #294
MDelaney's Avatar
MDelaney
Is it a 991.1 vs 991.2 thing? Mine does not do this either. (991.2 C4S) (Regarding pulling the paddles toward you together to go into neutral)
Old 06-18-2019 | 04:03 PM
  #295
BIGWORM's Avatar
BIGWORM
Both my 17 991.2 and 19 991.2 go into neutral if I pull back.
We use to have KICK DOWN too. Pull back on downshift, mash the gas and it will go to the lowest gear (think 7th to 4th) in a nano second and sling shot you forward. Porsche removed that and suggested we simply slide the stick over to automatic mode THEN mash it as its less effort IN THEIR EYES. Or we click it each gear manually . I liked kick down as I come from BMW land. Being able to go from 7th to 4th quickly in manual mode was nice. Now we have to downshift 3 times to get the same effect OR put it in automatic mode and let it do it for you.
Old 06-18-2019 | 11:24 PM
  #296
TimboCarrera's Avatar
TimboCarrera
You are at a stop light and the engine is at the higher sport idle. You want the lower normal idle but wish sport the instant you move, SO, momentary movement to normal and then to sport will now give you normal (lower) idle with sport mode active. Mostly... If the car is hot or many other things this might not work. I usually do this after engaging hill hold, need to try tomorrow while holding the brake. Also about the coast feature. A more accurate way to describe coast function is a quick pulling and RELEASE of both paddles. This technically is not neutral but the same as pushing the clutch in, more specifically both clutches.
Old 06-19-2019 | 12:50 AM
  #297
Cuda911's Avatar
Cuda911
So, I just went out to the garage and looked behind the seats (never folded them down before). Nothing back there and I never heard of the OEM sunshade. Was that an option? Or a standard item I should have?
Old 06-19-2019 | 11:18 AM
  #298
wareaglescott
Not included. I bought mine from Sun coast
Old 06-19-2019 | 11:55 AM
  #299
Cuda911's Avatar
Cuda911
Ah, ok, thx!
Old 08-14-2019 | 09:49 PM
  #300
Fred Crable's Avatar
Fred Crable
8th Gear
Originally Posted by achtung6
Yes. The owner's manual says to leave the key inside the car while washing the exterior. Easy fix. I'd be afraid to get the key wet if I kept it in my pocket while washing the car.
Kind of defeats the purpose of having keyless entry doesn’t it? Point of having the key in my pocket is I don’t have to take it out. This is how the doors work. IMO they need a new type of sensor for the frunk that is optical or more mechanical.
Quick Reply: Fun Facts about the 991 (please contribute)
