Adding Wireless CarPlay - 9XX Research?
#121
thanks for pointing this out, in my haste it was poorly worded and I've edited it to make it as clear as my previous post (see below)
If the iSudar wasn't avaliable I'd be happy with either joyeauto or NM with the NM winning on fit and finish but losing on cost. with all three as an option i stand by my opinion that most people should go isudar
#122
#125
So all these workarounds, NM, Joy, Isudar are basically the same. They act as "mirrors" to you phone, essentially.
You cannot download an app onto the PCM or or the new "boards", but if you download it onto your phone, you will see it on the new "system".
Are these more or less correct statements?
#126
Porsche_nuts (10-15-2021)
#127
This is how any car w/ carplay works, for example PCM 4.0 in the 991.2 and PCM 5.0 in the 992 both use your phone for the heavy lifting and the screen is just a display and touch interface.
The following 2 users liked this post by systemr:
bb964 (10-16-2021),
#130
#131
What size standoffs does it use (saves $10 on a smaller kit lol.)
So I installed this yesterday and I have no sound, radio or carplay I did the move the optical cable to the fitting at the pcm, but it has to be a problem with the optical cable right? Since I have no radio. I did select aux but it just selects it and then I go back to select it its on something else.
I also removed the xm card I am surprised you got it to fit! but Ill get standoffs and throw it back in I guess.
any tips on getting the head unit back it mine is a little less than an inch from going all the way in...
#132
Jim
#133
Thanks guys I got it, I reinstalled the xm card, used a couple of nuts with the supplied standoffs to get it to fit.
The no sound problem was the bulk connector not being pushed all the way in.
how do you go back to carplay after you have done something else on the pcm? I have to plug it in to get it to open back up.
