Adding Wireless CarPlay - 9XX Research?
#106
Truth being that they all work as advertised. The iSudar implementation was cheaper than the other options and didn't involve the installation of a secondary box and was only a card install into the PCM.
#107
I've been keeping my eye on this thread but been scared off by the mention of any loss of audio quality by hijacking the line-in. I have the Burmester audio so really don't want to have too hacky of a solution.
Has anyone does this mod with any of the options with Burmester?
#108
Tangerine (10-11-2021)
#109
I think that the answer that you'll get is that people like the solution that they installed.
Gixxerboy63 (10-11-2021)
#110
I have been very happy with my iSudar unit and find it to be as fast as the OEM unit in my Macan. I honestly can't tell the difference once the unit is running. I've had no complaints and I'm sure you'll be happy.
#111
That's awesome. You're the first person I've heard switch.
Thanks guys!
I now have the iSudar on order!
#112
I'll say it again. Yes I have the iSudar single board installation. Yes it works. Yes it works, Yes it works. Read the thread. I've said it a few times already, but one more doesn't hurt.
Just in case you missed it, yes it works as normal CarPlay and all the functionality is there and all the controls work as normal.
Thank you for the feedback!
#113
Hopefully yours won't arrive bent like mine, in a crushed box, two months after I ordered it. It did not work but did emit a burning smell. Fortunately the PCM is ok and I was dumb for attempting to install. Now I have to figure out how to ship something to China.
#114
#115
that sucks! i ordered mine last Tuesday and it should be here on thurs, supply chain problems seem to be getting better so hopefully the replacement will get here faster
as long as it works roughly the same (minus the volume control issue you've mentioned which I don't think impacts the joyeauto) I'll be happy with it since the box and wires are gone
#116
so the box/wires + two things that aren't a problem with NM vs Joyeauto made me do it: 1) can't use factory mic 2) needs to tap fusebox for power
Also bc the isudar is cheaper I was able to sell my joyeauto setup and upgrade to isudar for a net $5 since I do the install myself
#117
I tucked it between the carpet and firewall, due to the location I can't hide all the wires and I particularly don't like the wire heading into the fuse box. Under the steering column like in the auto amature video is even worse IMO for fit and finish
#118
Did Isudar send the correct length standoffs on recent orders? It seems to be hit or miss.
#119
i just did the isudar install to replace my joyeauto setup. it is (1) much cleaner install than joyeauto, likely slightly cleaner than NM auto (NM's external box is smaller and can be hidden) (2) significantly faster startup time (as in instant when the key ie turned to accessory) and maybe slightly more responsive that joyeauto which I've heard is similar to NM auto? config/setup screen before entering carplay is MUCH better/cleaner than the joyeuato setup and everything is configurable in software vs software + dip switches on the external box.
at this point IMHO nobody should use the joyeauto box for a new install and I'd even say not sure why you'd get NM auto except for the likely superior support from Nick. the isudar is cheaper, cleaner install and faster. Very happy with my iSudar setup.
install thoughts: fits exactly where the joyeauto board sat (use the same standoffs and screws actually) and basically the same install of the LVSD cables, easier to install b/c you don't have to route all the cables out to the external box but in some sense slightly harder due to the two cables that go into the PCM unit being thicker and originally unclear which side was up. Huge benefit that it doesn't need to tap fusebox for power (NM auto can, joyeauto can't) and that it can use the OEM mic (NM auto can, joyeauto can't). one thing that sucked or maybe it was how i had the cables situated but it was much harder to get the quadlock adaper/cables into the cavity behind the PCM so I could slide the PCM unit back in VS what I remember from the joyeauto install.
#120
NM Auto doesn't tap the fuse box, FYI. NM also uses the OEM mic...and there aren't any dip switches to mess with. Joyeauto and NM Auto are similar in some respects, but they aren't the same.
Glad to hear you're liking your new set up!
