PCM Issue with recent iOS Update?
#228
Hi All,
I had this happen in my 2013 991.1 Carrera S Cabriolet ironically the day that I took delivery of it from the dealer on 24MAY2020. Unknown to me they had provided a free 3 month Sirius XM trial so when the signal pushed to the PCM, the reboot cycle began. The car has PCM 3.1 and software version 3.43, the reason I mention this is I am unsure if it is affecting a specific software level for the PCM 3.1 units. Does anyone know what the most current version of software that can be installed in a 991.1 and other than having to take it back to the dealer is there an ISO where I can do that install? Note that I did the reset and handover procedure and it seems to be working for now, but I want to at least eliminate any other software issues due to mine being out of date.
Thanks!
Thanks!
#229
4.76 is the latest.
CD part # WKD-952-800-17
See this thread as well: https://rennlist.com/forums/991/8739...-update-3.html starting at post #85
#230
See this: https://rennlist.com/forums/991/1182...n-991-1-a.html
You may still be able to get the software update CD with 4.76 from the dealer. About $20 and you can do it yourself. Does not require PIWIS. My dealer installed it without charge. There is a video floating around nohow you do the update, but essentially you insert the CD and follow the on-screen instructions.
Another thread with a downloadable file; See this: https://rennlist.com/forums/991/1182...n-991-1-a.html
#232
Re-added bluetooth phone after a week and reboots reappear?
Yesterday, 5/31/2020, my 2016 911 cycled off and on - AGAIN. It took 4 times of resetting PCM Handover before the cycling off/on stopped. The PCM is functioning for now. Apparently there is no fix. This is such BS. My wife has not mentioned if the 2016 Macan is cycling off and on. The first time resetting the 911's PCM was 5/22/2020.
#233
#235
My car's XM reboot problem began May 20. The dealer performed the handover reset on May 21, and all was well for the next 6 days, although I did not use the car every day. Then the problem returned.
I did the second handover reset myself on May 29. The PCM has been through about 7 total hours of service and 6 or more vehicle on/off cycles since then, and everything is still working correctly. I don't want to jinx it, but I think my PCM is back to normal now.
shammerman (06-05-2020)
#237
No issues since my last message, approximately June 1.
Since then I've upgraded my pcm to 4.78 and sent a new activation via Sirius website.
This weekends surgery will be a hard drive clone and ssd transplant w screen protector and rennline mount install.
#238
Hi All, Talked to Porsche North America on Thursday this week and was told " the vehicle needs to go to the dealer for diagnostics before we can determine anything" well that's different from what I've been told for the last month!
So my wife will be following me to Winnipeg in July to go to the dealer for a reprogram of the PCM ( taking some equipment west for a friend), hopefully this will take care of the reboot problem.
#239
I'm very happy to report (at least for now) after 8 L O N G months of combined winter hibernation & CV-19 shut-down-stay-at-home-orders, I finally got the car out yesterday and I experience ZERO PCM rebooting issues. I hope I'm in the clear. Mainly because I don't want to do the hard reset and lose all my stored locations in navigation. Fingers and toes remain crossed.
#240
Seems to me what was happening is the update was corrupt so it would start to load and couldn't complete, so it just kept trying over and over again to load the files.
