What's Your Current 991 Covid-19 Project??
Old 04-02-2020, 12:41 PM
  #46
LexVan
LexVan's Avatar
Received 5,413 Likes on 2,516 Posts
Originally Posted by Porsche_nuts
Funny Lex - I was going to ask you the same thing! From the video, at the 4:30 mark, it does look like the guy is putting grease around the nut area as Mtony mentions. I originally thought that he put it around the edges as he uses a brush after he greases. But in looking at the vid several times, I do not think those two actions are related. Guess it would not hurt to put grease in both the nut area and the edges?
The blind leading the blind! LOL.
I plan to do only what Mtony says about the nut area. I can now easily see the black rubber seal in that area with my LED flashlight, now that I know what to look for. I plan to do it with maybe a Q-tip.
Old 04-02-2020, 12:43 PM
  #47
LexVan
LexVan's Avatar
I'll put this here.
If you are ordering supplies from Griot's, use the PCA Mambers code# "PCAGG" to get 15% off all your liquid items.
m5biemer (04-05-2020)
Old 04-02-2020, 12:44 PM
  #48
Porsche_nuts
Porsche_nuts's Avatar
Received 1,222 Likes on 739 Posts
Old 04-03-2020, 04:56 PM
  #49
LexVan
LexVan's Avatar
Grease tube is shipped. Will arrive Tuesday!
Old 04-03-2020, 06:36 PM
  #50
Norge911
Norge911's Avatar
so know we are lubing each other...........
Old 04-03-2020, 06:46 PM
  #51
LexVan
LexVan's Avatar
NTTAWWT.
Old 04-05-2020, 03:41 PM
  #52
ChaosHokie
ChaosHokie's Avatar
Thinking about an exhaust DIY project. I have a non-PSE Carrera S.... so either a Porsche PSE install or something else. Still trying to figure out what to do here, since I don't want the drone you get with most aftermarket stuff.
Also, thinking about a DSC controller "upgrade" and some radiator grills.
Old 04-05-2020, 10:14 PM
  #53
cvtbenhogan
cvtbenhogan's Avatar
I’m going to fix a loose dash vent on the passenger side. All the metal clips broke off and most were lost. Need to rig some metal pieces and epoxy these on the inner part of the vent. Pics to follow. But in the meantime I have a valve cover gasket job going on my bmw.
Old 04-06-2020, 12:58 PM
  #54
Soul Performance
Basic Sponsor
Soul Performance's Avatar
Received 1,910 Likes on 990 Posts
We've got what you need, and we don't have the drone. You can ask anyone running our setup on our 991.1 Valved Exhaust System Development Thread, or I'd be happy to connect you with someone running it as well. We also have the DSC controller available and everyone i know running it loves it
Valved Exhaust System for 991.1 Base Model
991.1 DSC Module
Regards,
John Gaydos
SOUL PERFORMANCE PRODUCTS
Quality Exhaust Solutions, Fair Pricing, and Outstanding Service
John Gaydos- Owner, Performance Specialist
Cell - (484) 883-6197
johng@soulpp.com
Jon Wheel - Marketing Manager
jwheel@soulpp.com
GT3FZS (04-12-2020)
Old 04-06-2020, 01:06 PM
  #55
diononiz
diononiz's Avatar
Originally Posted by Ceepe
I'm about 10 hours into my first paint correction. Decided to use a black 911 for my first attempt. It's not perfect but it's a lot better than the swirled mess the dealer delivered. Also got the DSC in but that takes all of 5 mins. If I had a proper garage and a lift I'd do some exhaust stuff. Enjoy seeing you guys having fun in the garage.
Can you outline the process and products you used? I just received my new Agate Gray 2020 Carrera S and it has several scratches and swirls in it I would like to remove. Also I ceramic coated my last 911 (2016 TTS) and decided to try again. I like the Gtechnique products and am excited to try the new G4 products
Old 04-06-2020, 05:15 PM
  #56
SConn
SConn's Avatar
I would hop on YouTube and check out some videos. There's a lot to the process if you want to do it correctly and it can go wrong in a hurry if you don't have the right tools (ie rotory vs dual action polisher) and technique.
If you are a complete novice, I highly recommend starting with The Junkman. He'll start you off nice and slow and is very beginner friendly. Once you've got a good base and some "playtime"uunder your belt, Larry Kosila with Ammo NYC is about the best you can get as far as knowledge and video resources. But, he gets very technical and can be discouraging when you don't have an understanding of what he's talking about and doing.
Old 04-06-2020, 07:42 PM
  #57
Ceepe
Ceepe's Avatar
2nd on all that. I started with some youtube videos. Larry (AMMO) is a good resource. His videos with Kevin Brown are really informative. Larry is local to me and has worked on my cars. I decided to simplify things and use Griots compete compound for the majority of cutting, a griots random orbital, and a chemical guys medium cut pad. It's amazing how much can be removed from that simple setup. Post wash and clay of course.
If Porsche didn't make the softest paint imaginable and my car was not black that might have been all that it needed. However on this car, whatever I took out I added in haze and lighter intensity marks. So then I went in with Adam's polish and a less aggressive pad which further improved things, reducing haze and eliminating more marks. I did not want to seal, wax or coat until I observed how it looked in direct high noon sun. Good thing because today I had the car in light where it was apparent that there was still haze and swirl on the hood. Subtle but there. So now I'm trying to learn what I need to do to remedy this. And after I touch that up I will seal or wax it. I have not really gotten to the coatings part of the equation.
It's been a fun process of learning online and experimenting during the past weeks. Hopefully I'm not blasting through too much clear, but I have learned that every single pass is removing something. It's an interesting pursuit and culture. My aesthetic is moving in the direction of well maintaining and knowing the paint, while not protecting it or avoiding usage damage. I find that the cleanliness and time spent is making me more familiar with its blemishes and I like the idea of it having them and knowing them, while also having well kept paint.
Jeahbladejeah (05-21-2020)
Old 04-06-2020, 07:46 PM
  #58
wbrownie
wbrownie's Avatar
I started the Cobb ProTune process for my Carrera T from @BBiAutosport . Very impressed with the results!!!
GT3FZS (04-12-2020)
Old 04-06-2020, 09:38 PM
  #59
SConn
SConn's Avatar
Can I just say how lucky you are, Ceepe, to have actually had Larry work on your cars? I would have loved to just watch him work!
Old 04-06-2020, 10:35 PM
  #60
Ceepe
Ceepe's Avatar
Yeah, Larry is cool. Here is a pic after he finished a correction on my 2015 GT3. At Speedsport tuning. We're also part of the same chapter of PCA, CVR. Good guy.
Quick Reply: What's Your Current 991 Covid-19 Project??
