How To: PDLS+ LED Headlights Retrofit
#62
Byte5 was disabled. Set it to enabled, coded, headlamps went through their initialization as they normally do when you write, but otherwise no detectable change (at least in my garage). I'll try to find an excuse to drive after dark and see if I notice anything.
Any idea what I'm actually looking for? A quick search and I'm not finding the exact difference in behaviour between USDM and ROW PDLS+. I was under the impression that it worked similarly to the new matrix light system on the 992 in that it wasn't an all on/all off situation with the high beams.
#64
#65
Sorry to say there were no detectable differences with the highbeams in auto mode. Still virtually useless in the suburbs here, bordering on a liability as they were flashing on and off as they detected themselves on reflective signs.
#66
Yeah, that's what I was under the impression of.
Shoot. Good to know. Thanks for trying. I do wonder if there's a missing step. We need some euro owner to send us a screenshot of their PIWIS output.
#67
Sorry if I missed it in the discussion or search (tried): how would this work on the 991.2 GT3?
Some reading suggests there’s no ‘plus’ with the GT3, so would that make it easier/eliminate the camera error issues? I assume the housing hardware is different as well.
I’d love to do this retrofit over the holidays so thanks in advance for the help!
#68
#69
#70
I'm actually working with a large Retrofit Company located in Asia, Fredles E Shop, you can find them on Facebook.
He said they've done PDLS Retrofits before, and, I'm actually after the LEDs, not the + Functionality just like you want it too. He said it should be no problem, and they can do it.
I'll also be doing the Keyless Entry/Go Retrofit, a 991.2 Steering Wheel Retrofit, PDLS, and also Retrofitting 18-Way Electric Sport Seats. Will keep everybody posted.
pazzom3 (04-20-2022)
#71
So when you say they’re working on it, do you mean a ‘kit’ of parts/harnesses?
#72
Does anybody have the wiring diagram for cayenne 2019 headlights ??? Would really appreciate it
I have piwis 2 but it only goes up to 2017
I want to try and compare the headlight to my current ones because every time I try to code them it says no programming data found
#73
#74
If it's not coding then sure there's a firmware difference, somebody with a ROW car should chime in with a VAL file, if they could be so kind.
#75
Hi Guys, I have done this conversion (PDSL Xenon to PDSL LED) on my 991.1 2012 and have a problem with the PIWIS coding.
The LED lights are working on basic functions (daylight, driving light and high beam) when the AFS module is disconnected, so i assume the wireing was done properly.
When I connect the AFS module and start PIWIS, I see the AFS module and all 4 modules from the LED lights.
The LED lights are than not working properly (only one of the LED are shining) But when I start the coding and calibration, i got several erros.
My suggestion is, that my BCM cannot handle the LEDs because it's from 2012 and I think the LED came from 2014 upwards.
The part number of my BCM is 7PP.907.064FL. Although the lights are not recognised via the Gateway.
Maybe the Gateway is also too old. Has anybody of you done this conversion on a 991.1 <2014 or can help me to choose the right BCM and Gateway?
