Techart/H&R vs GT3 height
#31
So looks like you dropped .75" front, almost .25" rear.
I am hoping for .5" front .25" rear with the Techart.
#33
#34
Gotcha. Yes, dropped 3/4 in the front and just over 1/4 in the back. Are you planning on doing the install yourself? The fronts are super easy and the rears are a super pain in the butt...if you need help or pointers let me know!
#35
Front looks like don't need to do too much. Strap springs, remove top nut, remove end link nut, and swivel strut out
Rear... what spring compressor did you use? I saw some guys saying they used very strong zip ties because a compressor doesn't fit?
#36
Yes, the rear was the worst. I have probably done close to 100 suspensions on various other cars over the years and this car (in the rear) was by far the hardest. For the rear, i used a snap on "claw type" compressor-worked on the factory springs but not to compress the H&R springs to get them back on...believe it or not I ended up using worm clamps and a vice to temporarily tighten two coils on the H&R springs enough to install them back on..def a pain in the butt.
AdamSanta85 (07-17-2019)
#37
Are you guys SURE Techart springs are made by Eibach and not H&R?
I was looking for assistance with bump stops on PN 091.200.120.009 (991.1 C2S), I can't figure out what they are speccing for my need, page 5, "2 - 991.343.301.05 - Helper spring FA" BUT for some of the models they spec "28880 VA-Z" which is an H&R bump stop. My spidey sense (8 years of working in performance automotive industry) is telling me Techart springs are actually H&R........
https://www.techart.de/fileadmin/med...f6c470cfa8.pdf
#38
No worries at all. I was just trying to do my due diligence on getting all the parts lined up. Turns out no need for bump stop swap on PASM-S C2S cars. I nearly ordered H&R bump stops last night, glad I held off.
#39
#41
At least I wasn't first... Ill put like 10 on it. I might try a ratchet strap as well. Should be fine.
https://rennlist.com/forums/991/9647...nsive-diy.html
#42
removing wont be a problem as you can get a spring compressor around the factory springs. Its reinstalling that is the issue-the wraps should be fine once you can compress the spring enough as long as you use enough of them.
#43
I just got my 991.2 back after having TechArt springs installed. PASM suspension with stock 20" S wheels and 7mm spacer in front. Definitely not as low as H&R's. The front for me is perfect, I wish the rear was just a bit lower. The ride quality is amazing. Could hardly notice any difference from stock in normal mode. Certainly not soft but I feel the stock suspension on the 991.2 is stiffer vs 991.1. Have not pushed the car just an easy drive home on familiar roads. I got exactly what I wanted vs.H&R so far = not quite as low and stock like ride in normal and a bit more firm in sport mode. Looks like its just a tad lower than SPASM which is right where I wanted to be. I could not stand the SUV look of the standard PASM suspension.
Very pleased so far!
AdamSanta85 (07-18-2019)
#44
Picked up some used Bilstein B16 Damptronic last night. I need to order the PDCC adapters which will take a few weeks to come. So probably not going install the Techart springs and will put them up for sale.
I measured a 991.1 GT3 last night, it was 27.25" floor to fender front and rear. I am aiming for this height, maybe a hair lower. This means .75" drop rear and .25-ish" front from PASM-S height.
