Has anyone done a CarPlay retrofit / Headunit replacement for 991.1
Old 06-11-2024, 01:09 PM
  #3151
Joec500
Joec500's Avatar
Received 1,021 Likes on 607 Posts
I scanned the thread and couldn't find the password for the screen dim adjustment. Is there a separate PW for that adjustment?
  #3152
Joec500
Joec500's Avatar
Originally Posted by oumizx
Hi I got my CHSTEK model installed in car toys. The installer said he connected the aftermarket backup camera to the model, but it is still black screen on it. He believed the wire setting is correct. He said what he used to do for other unit is to do some setting in the system to make the after market camera replace the original camera from factory(which my car does not have). But he could not figure out how to set it for this unit.
I tried to contact the seller on Aliexpress but got no response.
Any suggestion for it? Thanks!
Yah I have had other units that had a toggle for the use of an OEM camera OR aftermarket. I didn't see that toggle in our CHSTEK unit.
Old 06-11-2024, 01:28 PM
  #3153
andy2111
andy2111's Avatar
Old 06-11-2024, 02:48 PM
  #3154
bmxtreme
bmxtreme's Avatar
Originally Posted by cjrhoades
This was my biggest concern when swapping out the PCM, but after thoroughly looking into it, I didn't really have anything to be concerned about. Sport Chrono still functions as normal through the instrument cluster display, you just lose the functions of it only accessible through the PCM, which isn't much. Also, as Andy said, no nav or audio information will be available in the cluster display, but those maps are dated anyway. That's pretty much it. There can't be much locked behind the PCM because Porsche sold cars with just a shelf in the head unit spot if you wanted. All the needed controls are available in the instrument cluster display, and the aftermarket head units can also control vehicle functions via CANBUS.
I think we lost all steering MF controls like volume/phone etc as well ? (not that i have it ). And the cluster display also loses the Phone integrations? How about Mic? does this unit uses the car mic or it's own mic?
Old 06-11-2024, 02:52 PM
  #3155
cjrhoades
cjrhoades's Avatar
I don't have steering wheel controls, but they do still work with aftermarket headunits as far as I know. My Chstek unit has a menu for programming them. To be honest I forgot about the phone menu in the cluster because I didn't use it, but yes, that would also be gone. The headunit comes with its own mic.
bmxtreme (06-12-2024)
Old 06-11-2024, 04:35 PM
  #3156
bmxtreme
bmxtreme's Avatar
Originally Posted by ZedZed
Agreed - time to end this episode of the Foosh-ZedZed show I hope it's not been too boring for the others. Some good points made on both sides.
lol, honestly both solutions are same in the amount of effort. The PCB isn't that hard or complicated, if you can add RAM or change your PC motherboard CPU, you won't have any problems with this solution. BUT, I am not going to pay $500/$600 for a stupid $50 PCB solution or that $100 boxed PCB solution. Time for those sellers to get a grip of themselves.
Old 06-12-2024, 03:17 AM
  #3157
andy2111
andy2111's Avatar
Confirming the above. Steering wheel controls work, you lose the phone info in the MFD and the Chstek has an inbuilt mic which most people use, but there is also a standard 3.5mm adapter for you to plug in an external mic.
Old 06-12-2024, 03:41 AM
  #3158
bmxtreme
bmxtreme's Avatar
Thanks for confirming. That's a bummer, but I guess it's fine if you don't use the phone in the car often. AFAIK, most of these external mic is terrible compared to the built-in mic. At least the steering buttons still works which is really great though I have none on mine for now.
Old 06-12-2024, 05:55 AM
  #3159
ZedZed
ZedZed's Avatar
Re the phone, all you lose is the phone info in the MFD. With CarPlay or Android Auto the phone display on the main HU screen is way better than either the PCM or the MFD display and far easier to use.
You can buy a good mic for not much money and plug into the back of the HU. My Panamera unit gives me the option to use the OEM mic, but the unit in the Cayman doesn't so I installed an external mic. I located it on top of the driver side A pillar, with no visible wires. It looks pretty neat but you have to look closely to even notice it. Steering wheel buttons, if fitted to the car, still work as usual - you just have to program them one at a time in the relevant settings page. After that they all work as before.
Old 06-12-2024, 05:57 AM
  #3160
ZedZed
ZedZed's Avatar
Excuse OT post, but I know some in the thread are considering getting a Pedal Commander. If you are in the UK, you can get £35 off on the PC website using the code DAD35. Valid June 11 to June 17. Similar offers may be available in the US too - check locally.
Old 06-12-2024, 12:01 PM
  #3161
ralphsmit
ralphsmit's Avatar
Does anyone know what the voltage is of the pre-outs, it doesn't seem to be listed on the CHKSTEK website. I'm looking to add an amp so hopefully 5V.
Old 06-12-2024, 01:44 PM
  #3162
Joec500
Joec500's Avatar
Most of the time these are 2-4V, but I am running external amps on the pre outs without any issues.
ralphsmit (06-13-2024)
Old 06-16-2024, 07:31 AM
  #3163
bmxtreme
bmxtreme's Avatar
Looks like the CHSTEK doesn't have wireless android auto?
Old 06-16-2024, 08:13 AM
  #3164
andy2111
andy2111's Avatar
Yes it does, works perfectly for me
Have you connected it via USB for the initial setup?
Old 06-16-2024, 08:16 AM
  #3165
ZedZed
ZedZed's Avatar
It definitely does. What makes you think it doesn't? How are you trying to set it up? What phone are you using? I assume you have been able to set up AA using a USB cable? Is BT turned on on your phone and on the HU? Do you have Zlink on your HU?
Quick Reply: Has anyone done a CarPlay retrofit / Headunit replacement for 991.1
