Has anyone done a CarPlay retrofit / Headunit replacement for 991.1
#1682
You're right! Well done. Flipping that option fixed the backup camera issue. Thank you!
Oddly enough, the screen tearing was NOT happening when I was in the garage playing with the backup camera setting. So I'm becoming more convinced this is a board issue, either hardware or firmware, and not a connection issue.
Check out the word "Marriott" on the screen, you'll see it. It gets much worse than this at times.
#1683
I did the Isudar install and had issues with Entry & Drive and can only attribute it to the installation of the Isudar board as it went away after I pulled it. There were times I needed to use the physical key to unlock the car and then still would have trouble staring, getting the message "Key fob not found", so I'd have to resort to pulling the dummy key and insert the actual fob to start the car. I also had issues with the board hijacking my wifi LAN while at home after parking in the garage. Additionally I continually had problems with sound not being present, which was probably due to some setting in the PCM that would reset, but this was just another annoyance because of the Isudar board.
I installed one of the Android head units and so far it's like a blessing from heaven. The Entry & Drive issues that were troublesome, all went away. I couldn't be more pleased to have an updated system running wireless CarPlay natively and have a screen that looks much better and responds more quickly.
#1684
#1685
With the factory mic, call quality here was OK. With the supplied mic, call quality was better. Also, Google Assistant (similar to Siri) worked more reliably with the supplied mic. It may be the location of the supplied mic, or maybe it's a better mic - no idea. But that was my experience here. Obviosuly there are a lot of factors - signal strength, carrier, ambient noise etc.
In my Panamera, with the widescreen HU, I stayed with the OEM mic. In the Panamera the OEM mic is in a better location, and may be a superior mic to begin with. As the mic comes with the HU anyway, you might as well try both and see which is best for you.
#1686
You can add satellite radio quite easily and cheaply - you would need a satellite radio adapter box (Amazon) and an app to use with it (play store/app store). The adapter boxes have a brass connection which is meant to be used with the horrible antenna they provide with the box (meant to be stuck to the windscreen - ugh). But you can buy an adapter (Amazon) where one end goes into the sat radio adapter box and the other end into the OEM FAKRA connector for the OEM sat radio. The adapter box is powered by a USB connection which you can arrange behind the radio using one of the spare USB connectors provided with the HU, so the result is invisible.
Which OEM features do you have in mind when you say you would lose some of the integrated features? Obviously, you would lose anything which is exclusive to the PCM itself, since that will have been discarded and replaced by the new HU - so that would be phone, satellite navigation and the original radio. All three of those will be replaced by the HU. I can't think of any other integrated features that I have lost.
Here is the first sat radio adapter that came up on my search - there are loads of them, and many much cheaper than this. In the UK we have 'DAB' radio (Digital Audio Broadcast) - in the US I believe this is called Sirius or something like that? Your local Amazon should have the correct adapter I would expect.
This is the kind of antenna adapter you would need to make the installation totally invisible:
I don't think any of the HUs have satellite radio built in because the frequency bands vary from country to country.
I guess I could look at the spec sheet and find out. I’m just being lazy now.
#1687
Screen issues are often related to incorrect seating of the ribbon cables. It might be worth checking that they are all firmly seated, parallel to the connector with the lugs pressed down firmly, if you haven't already done that. If you have done that and the screen still tears up, then it is probably some other issue and points perhaps to a faulty board.
ZedZed (12-05-2023)
#1688
In my unit, I tried the factory mic, which worked OK. But when I tried the supplied mic, it worked better. This may be for various reasons: the factory mic is old tech in my wife's Cayman where the supplied mic is, presumably, up-to-date. Also, the factory mic in the Cayman is behind the steering wheel inside a plastic shroud. I routed the supplied mic through the A pillar, behind the rubber seal, and out at the top corner of the windshield. No visible wiring and if you didn't know the small mic was there, you'd never really notice it.
ZedZed (12-05-2023)
#1689
I have been using the factory mics located in the steering column housing. But like Zed, I think I'll be using the one supplied with the kit. People have said they have trouble hearing me. However before doing that I'll see if upping the gain in the mic will help. There are menu settings for doing this. That said, I've had no issues accessing Siri with the mic.
ZedZed (12-05-2023)
#1690
My bad - sorry for the misunderstanding. I am using TuneIn and/or Replaio for radio (with Android Auto) and these give me thousands of streamed radio stations, which is OK for me. I generally listen to Tidal when on the move anyway, and only use radio (usually) for news broadcasts or 'talk' stuff.
#1691
Live Steam (12-05-2023)
The following 2 users liked this post by flgfish:
Larson E. Rapp (12-07-2023),
ZedZed (12-07-2023)
#1693
New to me car! Do i have CarPlay ?
Purchased a 991.1 and when I press info I get these screens
my phone can not find the vehicle however the phone also asks for me to press the voice control button to pair.
please help - its a quality of life matter.
The version of my pcm
The suspect CarPlay screen
