Break-in Oil Change?
#31
Your dealer is wrong on the frequency. OP should look at his manual and service reminder in his MFD. It's 20k miles on the 991.2. Engineers won over the lawyers on this point. The increase in frequency to 20k for the new 911s was discussed in another thread: https://rennlist.com/forums/991/9986...-services.html
Oil maintenance
As per fixed service reminder indicator, at the latest after 10,000 miles or 1 year.
There are two sections in the booklet- Oil maintenance and maintenance. The maintenance section is everything else EXCEPT oil changes and is every 20,000 miles.
#32
Received 2,260 Likes
My 991.2 maintenance booklet states:
Oil maintenance
Oil maintenance
However, getting back to the OP's original question on the "official recommendation" for the oil change frequency, it is annual or 10k and not sooner.
#33
I wonder why BMW changed their oil maintenance interval from 15000 to 10000 to 7500 miles. Maybe they realized that the service interval was to long and started to see signs of early engine wear. Now the computer is set up to 7500 miles oil interval change.
#34
My lord guys...it's a friggin oil change...change at 1000 or 2000 if it make you feel good or changing weight for track use or 10,000 just change by 10,000. Your NOT going to hurt anything by changing oil before 10,000 miles.
#35
#36
I am speaking about the oil change interval. From 15000 miles by computer about 8 to 10 years ago, to 10000 and now 7500 miles which I believed changed two years ago.
#37
So, long term engine care aside (and debates about the ultra-precision of modern Porsche engines), the core issue here is the value of a short duration "break in" oil change. Again, engines built in 2017 are almost certainly cleaner and true-to-tolerance than decades ago. But...any initial break-in period is likely to produce more contaminants than the same engine with 20k miles. So for minimal cost, why not change out that first oil and filter sooner?
#38
Subshooter - give us all a break, everybody on Rennlist knows you are violently opposed to changing the oil before 20k miles, or the actual recommended interval of 10k miles. Not everyone agrees with your philosophy, so stop trying to bend the universe to your will. I would venture a guess that each of us that is buying a brand new 911 is also mature enough to make our own decisions about an OIL CHANGE. So next time it comes up, just bite your tongue (or keyboard) and move on with your life.
#39
Good thought since I did European Delivery but the MFD was definitely in miles (at 20k miles). Same with OP in this thread. https://rennlist.com/forums/991/9986...-services.html
I don't have my car back yet from Europe so I can't check the service interval in the scheduled maintenance booklet. Car is sitting at my dealership so when I get it Saturday or Tuesday, I will look it up and post back in this thread to ensure we and I are not spreading false information. I will include pictures of MFD service interval as well.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
![](https://cimg5.ibsrv.net/gimg/rennlist.com-vbulletin/640x480/manual_1_b14de42cd88ee0aaaaf74ed343f479834ded61ee.jpg)
![](https://cimg6.ibsrv.net/gimg/rennlist.com-vbulletin/640x480/manual_2_ad22779c262e12792008d8b5f1d5c0f2ec9eedde.jpg)
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/640x480/mfd_4db68b5384ab88f9dd06d7b91cf52388ca34668d.jpg)
#40
Look at the other interval. Your MFD screen shot is for the inspection, the other is called oil service. I bet it says 9900 miles and 8/2018 for the oil service.
#41
#42
Received 5,412 Likes
Hey Subshooter, how ya doing!
Sounds like we got this whole service interval figured out, finally. It's all good.
So, I wanted to come back to this comment from last week. And then maybe we can get this sucker to over 12 pages.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I think I made this challenge in another thread, but, I'll make it here again. I challenge someone to post a better (wear metals; iron, copper and alum) Used Oil Analysis than mine. I think I am having the excellent UOA results that I'm getting mainly because of:
1) early oil change at 1,000 miles
2) car actually gets driven
3) <4,000 rpm until oil hits +180F
4) using quality oil (Mobil 5W50), 5K drain intervals, all maintenance done on schedule
So, I don't agree that it's only a "feel good measure".
#43
Since Porsche recommends an oil and filter change every 10,000 miles or annually, whichever comes first then we are safe, right? I don't think so for the following reason:
The manufacturer tests engines under normal drive conditions. If you are driving on the track regularly or engaging in very spirited driving engine wear will increase over the normal testing range. Therefore, the engine oil will become filled with more contaminates than normal and the oil filter will trap more of these contaminates under more stressful driving. The filter will become less efficient as the media sustains more contaminate buildup.
As far as I know (could be wrong) Porsche does not make any modifications in oil and filter change service interval for their Carrera lineup. They do however recommend a different service interval for GT3 and RS service interval if they are tracked. That interval is 3000 miles. Since we know that Mobil 1 will not oxidize at temps up to 500 degrees (our temps generally do not reach 260 degrees), one can only conclude that there is concern about the efficiency of the filter and increased contaminants.
#44
i do mine every year, regardless of miles. probably over-kill, but i like to spoil my car
#45
I just eclipsed the 2000 mile mark on my .2 C2S so I'm finally done with the engine break-in…. I got a chance to launch yesterday afternoon and it was noticeably quicker than my M4! It’s amazing how well these cars can put the power down. I've heard some members say that they performed an oil change at this point but the dealer said I don't have to do anything until the 10K/1 year mark. What is the official recommendation? Thanks!
I also don't agree with a 2k mile sub 4K RPM break in being good for the engine either. With no mention of lugging the engine (which is far worse for break in). Makes no sense to me.
