Sponsored by: Road Spy
Tracking the Turbo
Old 11-01-2023, 09:18 PM
  #316
VaderCab
VaderCab's Avatar
Originally Posted by Manifold
Sure you want to track a turbo cab? If you do, maybe just use the car in stock form with PS 4S tires and don't go above 8/10ths of your ability.
Thanks. I am not particularly worried about tracking in the Cab. It has factory roll-over protection. If PCA is good with it, I'm good with it.
Originally Posted by Randyc151
I'd still go with the best tires you want to spend money on, but agree on the 8/10. Also, probably don't flip the car!
(Does anybody have a story of a 991 TTS flipping or rolling on track?)
Agreed, Randy. And thanks for the info this morning via text.
Originally Posted by Bluemax2
I run Cup2s in factory N1 sizes. In many cases the Cup2s in Porsche N1 specs have a bigger foot print then the larger sizes also staying within the spec for the AWD system.
Thanks. Messing with the AWD system with taller tires was one thing I was worried about (though seems like a nonissue for those running 265/325?). I also like the idea of staying N1 spec. I was looking at 255/315 PSC2s also; the 255 is N0 spec (also Porsche), but the 315 is K spec (Ferrari). Not sure how that would play. (They both use horses for logos, right?)
This is the alignment I have been running with factory parts for the past year with excellent tire wear. The only thing that has been changed suspension wise is the addition of a DSC Sport Controller ( highly recommend )
Front -2.7 Camber toe at 1mm out
Rear -1.7 Camber toe at 1mm in.
Thanks! This is very helpful. You were able to achieve those alignment settings on factory parts? I am surprised you got that much camber on OE parts and had resigned myself to new control arms and/or camber plates from Tarrett. Not so? Also, are you running those settings on the street, too?
Old 11-02-2023, 12:21 PM
  #317
Bluemax2
Bluemax2's Avatar
I was going to do the up-size on tires also until l took a hard look at the specs. I didn't want to mix the different compounds. Personal choice.
I drive my car as a daily and between HPDE and other track events the alignment works well. I get 8-10K miles on a set of tires including seven events on my current set.
Old 11-02-2023, 12:42 PM
  #318
VaderCab
VaderCab's Avatar
Makes sense. I’m leaning that way too.
Old 11-02-2023, 12:58 PM
  #319
Manifold
Manifold's Avatar
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 4,430 Likes on 2,520 Posts
PCA allowing something doesn't necessarily mean everyone should it consider it to be 'safe enough'.
For years, PCA allowed using harnesses without using a HANS. Now that's no longer allowed.
I can put slicks on my 992 GT3 and drive 10/10ths with street brake fluid, street pads, 3-pt belts, windows down, open-face helmet, and flammable clothing. PCA allows it, but many would say that's not safe enough.
911Königin (11-02-2023)
Old 11-02-2023, 02:58 PM
  #320
VaderCab
VaderCab's Avatar
Definitely avoid tracking in a Cab if you're afraid to do so. But I don't share your concern.
Old 11-03-2023, 12:28 PM
  #321
drabe
drabe's Avatar
I have a stock 991.1 TT with full Tractive package from TPC. No understeer at all
Old 11-03-2023, 01:30 PM
  #322
42THFLR
42THFLR's Avatar
Hi drabe. Do you run your car with this setup on the street as well as the track, and if so, what are your perceived differences over OEM on the street? Also, if you drive to and from the track, what changes do you make once at the track and how, if you do? Thanks
Old 11-07-2023, 09:17 PM
  #323
VaderCab
VaderCab's Avatar
Did those of you running -2.5* of camber up front install axle spacers? I’m seeing several sites (e.g., E-Motion, Tarrett) recommending (and selling) axle spacers supposedly to prevent damage to the axles and transmission from added camber.
Are those only necessary when going to extreme camber, or do I need to factor them in?
Old 11-07-2023, 09:20 PM
  #324
flsupraguy
flsupraguy's Avatar
Received 1,499 Likes on 805 Posts
Anyone still tracking their 991 turbo in 2023 with upgraded turbos and meth injection?
Old 11-08-2023, 11:39 AM
  #325
Bluemax2
Bluemax2's Avatar
2 years in with my alignment and no problems yet on all stock parts.
Old 11-08-2023, 11:52 AM
  #326
Bluemax2
Bluemax2's Avatar
I believe @KONG991TT Is running upgraded turbos but not sure about Meth. I would think it would be hard to run Meth on a road course.
Old 11-11-2023, 08:53 AM
  #327
VaderCab
VaderCab's Avatar
Water/meth would be great to keep temps down, especially since so many tracks seem to be in the desert out here. I wish there were a clean setup for a small tank that didn't take up precious frunk space.
Old 11-11-2023, 08:57 AM
  #328
flsupraguy
flsupraguy's Avatar
Be nice to find a way to make the OEM GT2RS tank fit
Old 11-11-2023, 11:03 PM
  #329
bigrpowr
bigrpowr's Avatar
i am about to start trying it, but i plan on leaving the meth off for now and running on a 95 octane or so. no idea how it will work so i figured starting as low on power as possible.
Bluemax2 (11-13-2023)
Old 12-09-2023, 04:50 PM
  #330
VaderCab
VaderCab's Avatar
With all the talk of the 265/325 setup in this thread, just a heads up that I have a brand new set of PSC2s in 265/35-20 and 325/30-20 for sale in the marketplace: https://rennlist.com/forums/market/1381983
Quick Reply: Tracking the Turbo
