What did you do to your 991 turbo today?
#1891
Wow, that thing is ginormous.
I'm guessing you have a big wing coming to finish it off?
BTW, what's your suspension setup? I see a ton of camber in that pic. \m/
#1893
When I had a coil start to go bad, I had CEL's for half a dozen unrelated systems in the car.
I also can't imagine going without at least a basic Porsche code reader. I have a durametric and a PIWIS clone, but my go-to for a CEL, resetting an airbag light, etc. is one of the Porsche specific handhelds. I've been pretty happy with the Foxwell NT530 (make sure to get it loaded with the Porsche software), about $170. Typical first step with an issue like that is to pull all codes, note them (I usually take picture of the scanner, easier than connecting it to my computer) clear them and see if they come back... A minute or two with the scanner.
I know some others use the icarsoft scanner which is a bit cheaper, probably works great as well, but I can personally vouch that the one above works on my 996 Turbo through my 991 Turbo..
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/909x950/zzz_22a4a398b33005e5dcf58a000afabd50124e1dba.jpg)
#1894
Received 2,108 Likes
It's kind of crazy how one root cause, even a minor one, can cause all kinds of wildly unrelated faults to pop up. Low voltage is notorious for that, or it might actually be a problem.
https://www.amazon.com/gp/product/B07XQJG3NB
Awesome Paul!! Thanks for the info.
Got a buddy hopefully meeting me when I get off duty to pull / clear the code.
One guy that had a code pop on Sunday also said he went away. Other guy had his code pulled and it was a P0456 - Evaporative emissions system leak detected (very small leak)
Cleared it and it didn't come back yet. Hope I get that lucky.
#1895
You didn’t by any chance fill up with gas prior to getting this message did you?
Big Swole (11-18-2020)
#1897
#1898
My bet is once cleared it will be gone. Nothing major. These computers are always comparing operating inputs to “ideal state” within a tolerance. Small changes in things like air density and barometric pressure can trigger a message such as this. Your dealer will probably reset and send you on your way.
I hope you're right. I think it may go away too.
My buddy had to head home tonight so he's going to drop by tmrw. evening to clear it for me and see.
Some did but I didn't. I filled prior to leave my city to head to the meeting spot.
Once I switch to Cobb ap, this won't be a problem to have to rely on the dealer or friends to clear / check codes.
Or buy a scanner tool like Paul posted.
#1899
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/560x375/image_2020_11_18_192737_a9762ac14eefdf6e5ec9221f6753acff2f2960db.png)
#1900
Good Point!! ^^.
#1901
Spage Sport made it for me. They're local to me. Conservatively speaking it should be about 200lbs at 200km/h. We'll get final numbers once the wing and other aero bits are on
LOL! yeah 1/3 of the screen is covered but now i just use that as safety line
Yup, RSR style wing coming in the spring. I'm just lowered on H&R springs but maxed out the oem camber
Close, GT2 RS Deck lid. Comes with everything you mentioned in one, less a wing
#1903
- I'm assuming you are still using the stock turbos and headers?
- How are you dealing with heat control around these areas? I know on the 2RS they have air inlets around the headers
- Is it Dry Carbon?
- What are you doing upfront to balance the car?
#1905
Looks great.
And doubles as a car seat for unruly children...
