Centerlock Wheel Installation Comments
#46
4pages of comments on how to take off wheels?! I doubt a 5-lug thread would be as long.
Kudos to all you gentlemen who have the patience and fortitude to put up w/ Porsche's rendition of the wheel. I for one am not so I'll wait for a 5-lug.
#47
I have this tool in my notes, I believe someone mentioned its the same make as the snap-on
#48
I see this one but it doesn't have the breaker bar feature:
#49
http://www.toolsource.com/inch-drive...-p-149886.html
#50
It's a new system for most of us. The CL wheel was a big mystery to me because I didn't understand how it completely worked, and I didn't have the necessary tools. Once you have the tools, the only real difference in my opinion is that you have to apply the anti-seizing goo but the rest is pretty much the same procedure as the 5-lug (raise lift, apply brake, remove, re-install, apply brake, tighten, torque, and lower lift). If no greasing was involved, the CL wheel change-out is probably faster.
#51
The torque multiplier doesn't seem like the ideal tool. The reaction bar has to be placed against the ground for the multiplier effect to work, so then to "back off" the CL after the first torque sequence you'd have to flip the reaction bar around to apply torwue the other direction, and then back again for final torque. Add to that the +/- 10% torque uncertainty and it feels a bit sketchy compared to the long bar. The pro is certainly that you don't need a new torque wrench, but the con is you have to have something to react that bar against during torquing.
What do folks think?
#52
The Precision Instruments wrench bigkraig referenced is made by a company owned by Snapon and they make Snapons tools. I just received mine from Tooltopia for $320 including shipping and carrying case. Quality product.
#53
Hilarious you think that 5 lugs involve the same process as CLs and that only the grease makes changing CLs take longer!
Let me put it simply : 70% of folks putting 5 lugs on do not use a torque wrench and are fine,as long as they follow a star pattern tightening sequence and do not torque the heck out of them to the point of breaking. Even if they torque them too much,wheels do not come off,but they might warp the rotors. Use an impact and it will take you 30 seconds per wheel.
CLs on the other hand : follow the exact procedure or you're f**ked!
#54
Hilarious you think that 5 lugs involve the same process as CLs and that only the grease makes changing CLs take longer! Let me put it simply : 70% of folks putting 5 lugs on do not use a torque wrench and are fine,as long as they follow a star pattern tightening sequence and do not torque the heck out of them to the point of breaking. Even if they torque them too much,wheels do not come off,but they might warp the rotors. Use an impact and it will take you 30 seconds per wheel. CLs on the other hand : follow procedure up to a T or you're f**ked!
I concur that you have to follow the CL procedure meticulously as it doesn't offer the same redundancy the other.:O
#55
The 70%-I've made that number up. I don't know exactly how many torque their 5 lugs using a torque wrench,but from my observation most do not...
#56
Always, properly torque your wheel bolts, lugs to the mfr settings. It is way too dangerous not to do so, especially if you track your car.
#57
Every tire shop here uses a torque wrench. I've always used one for the past 15 years. Many times the issue is over torquing the lugs. Then they can crack and snap off while driving. I've seen this at the track, and unfortunately experienced this myself with catastrophic failure.....on the highway, and a stud cracked. With the wheel rotation it was only a matter of seconds before they all broke and the wheel came off. Fortunately I came to a stop right as the wheel dropped. This was in a Dodge Durango in 2000. Always, properly torque your wheel bolts, lugs to the mfr settings. It is way too dangerous not to do so, especially if you track your car.
But trust me,around here I haven't seen one shop that torques wheels,NOT ONE! Shops are the worst offenders!
#60
