What did you do with your 987 today?
Old 08-27-2023, 01:58 PM
  #1336
scootr
scootr's Avatar
Took her out early for a top down drive up the mountain. Cooler up there, overall a wonderful 100 mile drive. Beautiful long views of oaks, pines, cactus, brush, and rock.
Where was I ?
Now for a wash....
The following 2 users liked this post by scootr:
Chris MI 987 (08-28-2023), porsche_rrr (08-27-2023)
Old 08-28-2023, 03:10 AM
  #1337
Cayman292
Cayman292's Avatar
Getting ready to remove the front bumper cover to replace a leaking condenser and replace the drier on my 987.2. If any of you guys have any tips or special insight, feel free to comment. I watched a youtube on it and it doesn’t seem to be too complicated. There aren’t any shops close by that would know about Caymans so I’m going to do what my dad taught us growing up, figure it out. I’m going to install the screens while I have the cover off and hopefully we won’t get another leak.
Thanks in advance.
The following 2 users liked this post by Cayman292:
porsche_rrr (08-28-2023), scootr (08-28-2023)
Old 08-28-2023, 09:23 AM
  #1338
The Duke
The Duke's Avatar
Thanks in advance.
@Cayman292 I have just removed and replaced my bumper for the second time in the last two years. I intended to post something on it, but I haven't yet had the chance.
Two tips that I can offer -
1) There are about 20-25 T25 & T30 screws that Porsche uses to attach the bumper and inner wheel wells to the unibody. To ensure that I was able to successfully put them back where I took them from, I found it useful to create a list of what went where.
2) The headlight/foglight wiring harness is attached to the unibody. If you know how to disconnect it, it's a trivial piece of work. If you don't, you may get very frustrated and break it. At the 7:14 mark, this vid shows exactly how to take it apart,
And - no - I will not receive any form of compensation if you click on the above link :-)
Old 08-28-2023, 09:46 AM
  #1339
ClemCLone
ClemCLone's Avatar
Thanks in advance.
There are 2 metal clips each side of the top of the bumper cover, between the fender and the bumper cover.
Passenger side Bumper Clip
They are a bitch to remove, especially if they are rusted in.
I had to replace both of mine.
992-807-891 Porsche
If you insert a small screwdriver or pick tool, under that edge-flap, left side, it releases the clip from the bumper and you can pull out the right-angle end with the hole in it. Mine were so rusted, that flange broke off.
Old 08-30-2023, 10:30 PM
  #1340
jazztrip
jazztrip's Avatar
The summer maintenance program on my 987.2 S track car has included:
  • Replace Tilton pump for PDK gearbox cooler (previous one had cracked after 8+ seasons).
  • Added BRS Billet PDK Transmission Pan for slightly better cooling and simpler filter replacement.
  • Oil change with Motul 300v Competition (15W50)
  • Remove bumper cover and clean radiators (long overdue).
  • Four new Fikse three-piece wheels. My shop had discovered four cracks in the right front wheel (gulp!). The old CCWs had worked hard for 8+ seasons and it was time (overdue) to replace them.
  • New wheels studs all around. Again, the prior studs had gone 8+ seasons.
  • Lastly, this past Monday I took her in for an alignment and corner balance.
  • Next up, I'll do new pads (Ferodo DS1.11) and a semi-annual brake fluid flush (SRF)
Looking forward to my next HPDE at Motorsport Ranch in Cresson TX in late September. Hopefully we'll be done with 100+ *F days by then.
The following 2 users liked this post by jazztrip:
porsche_rrr (09-03-2023), vitaminC (08-30-2023)
Old 08-31-2023, 10:28 AM
  #1341
The Duke
The Duke's Avatar
that's a beautiful Cayman!
The following 2 users liked this post by The Duke:
jazztrip (08-31-2023), porsche_rrr (09-03-2023)
Old 09-01-2023, 01:37 AM
  #1342
Zepper
Zepper's Avatar
I freshened up the touch points on my 2009 base box.
2023 Cayman GT4 wheel in alcantara. Custom made shift **** from Built by Basil.
I am not stoked about the alcantara shift boot...yet. It is such a flexy material the stock leather or vinyl holds a crease much better. I have to tighten it down better.
Would love to find those 1/8" staples porsche uses to hold the stock boot.
The following 3 users liked this post by Zepper:
dave_987 (09-01-2023), jazztrip (09-01-2023), porsche_rrr (09-03-2023)
Old 09-01-2023, 10:59 AM
  #1343
Zach L
Zach L's Avatar
Martini Racing? Looks great
Old 09-01-2023, 11:38 AM
  #1344
Zepper
Zepper's Avatar
Yep Marrrtini Racin.
Thanks, i wanted to add little color pops to what is an otherwise bland color combo meteor grey exterior and black interior.
Old 09-01-2023, 12:02 PM
  #1345
bredward
bredward's Avatar
My girlfriend's colleagues invited me to do some open lapping at a rented track a few weeks ago.
The following 4 users liked this post by bredward:
Chris MI 987 (09-04-2023), jazztrip (09-01-2023), porsche_rrr (09-03-2023), Zepper (09-01-2023)
Old 09-03-2023, 10:30 AM
  #1346
Bibbs
Bibbs's Avatar
Rewired my shift lights, swapped the frunk/trunk door sill switches, and adjusted the elastic on the roof.
The following 2 users liked this post by Bibbs:
Chris MI 987 (09-04-2023), porsche_rrr (09-03-2023)
Old 09-05-2023, 02:39 PM
  #1347
HerrOberst1969
HerrOberst1969's Avatar
I had my 06 Boxster base towed to my Indy as I think a belt broke, a pulley came loose or the water pump failed again. I did have the top down so that was the only plus of the morning lol....
Old 09-05-2023, 03:47 PM
  #1348
Dave in Chicago
Dave in Chicago's Avatar
Cruise control switch on clutch pedal. Thanks to forums and YouTube folks for diagnostics and tips.
Seems to have cured an intermittent cancellation of the cruise control. I drive a ton of miles, so it’s a surprisingly important feature for me.
Chris MI 987 (09-05-2023)
Old 09-07-2023, 03:18 PM
  #1349
Neyurt
5th Gear
Neyurt's Avatar
Default Bought a 2009 Base Cayman!
Wasn't today but bought this last week. My first Porsche!
2009 Base Cayman. Manual @ 29k miles.
Feels brand new!
Travelled 3 hours and drove her home.
The following 12 users liked this post by Neyurt:
BWJones (09-07-2023), Cayman292 (09-07-2023), Chris MI 987 (09-08-2023), dave_987 (09-11-2023), jazztrip (09-07-2023), joliver3 (09-07-2023), porsche_rrr (09-07-2023), spyderbret (09-14-2023), tcal765 (11-05-2023), The Duke (09-07-2023), vitaminC (09-07-2023), Zepper (09-08-2023) and 7 others liked this post. (Show less...)
Old 09-07-2023, 03:21 PM
  #1350
BWJones
BWJones's Avatar
YEEEEEAAAAAAAAAH! Nice find. Congratulations and welcome to Porsche ownership.
Quick Reply: What did you do with your 987 today?
