What did you do with your 987 today?
Old 07-03-2024, 12:02 AM
  #1591
vitaminC
vitaminC's Avatar
Originally Posted by Zach L
Stunning results! What products/process did you use?
Thanks! So far just starting with Griot’s synthetic clay and BOSS fast correcting cream - both done with a random orbital. I’m still planning on another more gentle polish and then top it with something for protection.
porsche_rrr (07-03-2024)
Old 07-03-2024, 02:21 PM
  #1592
mspalacios
mspalacios's Avatar
Hardwired a Valentine One Gen 2 that discreetly hangs off the sun visor.
The following 3 users liked this post by mspalacios:
Matt(inMA) (07-06-2024), porsche_rrr (07-03-2024), sasilverbullet (07-03-2024)
Old 07-03-2024, 06:27 PM
  #1593
sasilverbullet
sasilverbullet's Avatar
Put my new wheels I painted along with my new Kumho's on today...
The following 3 users liked this post by sasilverbullet:
dxrohanx (07-04-2024), J Free (07-04-2024), porsche_rrr (07-03-2024)
Old 07-03-2024, 06:33 PM
  #1594
old man neri
old man neri's Avatar
What kind of Kumhos?
Old 07-03-2024, 07:34 PM
  #1595
sasilverbullet
Ecsta V730's, the rears are 265/35, fronts 245/40.
Old 07-04-2024, 05:48 PM
  #1596
Schwinn
Schwinn's Avatar
Installed Aliexpress LED turn signals in the rear of the 987.2 - the car has a wacky bulb assembly for this, but the Ali bulbs worked great and are low cost. Here's one installed, to compare to the stock bulb (yes, the other turn signal is actually on!):
MUCH brighter and almost a drop-in replacement... I'll take it!
The following 2 users liked this post by Schwinn:
porsche_rrr (07-04-2024), sasilverbullet (07-04-2024)
Old 07-04-2024, 05:58 PM
  #1597
nicetheory
nicetheory's Avatar
How did you hardwire it?
Old 07-06-2024, 12:50 AM
  #1598
Dave in Chicago
Dave in Chicago's Avatar
Installed new Porsche rotors, pads, caliper hardware, and sensors all the way around. Second time I’ve done this on the car (I drive a lot of miles).
Flushed / power bled brake system and clutch. Clutch slave is more accessible than I thought.
Oil and filter change, with sample sent out for analysis, per usual.
Maniacal attention to torque specs. Minimal blood loss. 😉
Not looking forward to freshening parking brake bits. Lots of springs and stuff in there. 😬
The following 2 users liked this post by Dave in Chicago:
porsche_rrr (07-06-2024), SeanPatrick31 (07-06-2024)
Old 07-06-2024, 09:45 AM
  #1599
mspalacios
mspalacios's Avatar
Ran the flat Valentine 1 Gen 2 power cord from the fuse box into the A pillar (just yank it out) into the windshield trim strip after removing the sun visor. Used an add a circuit tap in a switched fuse.
Old 07-06-2024, 09:46 AM
  #1600
mspalacios
mspalacios's Avatar
Default Obligatory
The following 2 users liked this post by mspalacios:
Cayman292 (07-07-2024), porsche_rrr (07-06-2024)
Old 07-07-2024, 04:54 PM
  #1601
andrewro
andrewro's Avatar
Not today but rather last weekend, at around 15 months and 6k miles of ownership, I turned 90,000 miles during the first leg of a 750 mile road trip. It was pretty anticlimactic as I was stuck in an interstate standstill.
I've done a fair amount of upkeep this year including a clutch and flywheel job, timing chain tensioners, drive belt pulleys, plus a newer steering wheel from a Macan, Rennline wheel studs, and probably some other things I'm forgetting.
If I couldn't do this work myself there's no way I could justify having this car! What a fun machine it is and I'm glad to be back in Porsche world after several years away.
The following 2 users liked this post by andrewro:
Cayman292 (07-07-2024), porsche_rrr (07-07-2024)
Old 07-08-2024, 02:37 PM
  #1602
KrisA
KrisA's Avatar
A couple of updates to the old Cayman. Full OEM Cayman R suspension installed, right down to OEM bearings, top mounts, bump stops, etc. Custom 19" wheels made to emulate the old Speedline wheels used on Ferrari Challenge cars in the 90's. Wheels and tires have some heft to them, each corner is about 5lbs heavier than stock, but they look good and the weight gives me an excuse to keep my 18's around, with spacers. Last piece of this years puzzle is get my new seats installed, just waiting for a Durametric Pro to show up to start coding before wrenching.
The following 6 users liked this post by KrisA:
andrewro (07-09-2024), BWJones (07-08-2024), Cayman292 (07-08-2024), porsche_rrr (07-08-2024), sasilverbullet (07-08-2024), vitaminC (07-08-2024) and 1 others liked this post. (Show less...)
Old 07-08-2024, 03:35 PM
  #1603
BWJones
BWJones's Avatar
I loves me a 5-spoke wheel.
Old 07-08-2024, 04:27 PM
  #1604
sasilverbullet
I like the look, kinda 959'ish...
Old 07-08-2024, 09:27 PM
  #1605
nicetheory
nicetheory's Avatar
Where do you get your torque specs? Can you share this with me for my 987.2 work?
Quick Reply: What did you do with your 987 today?
