My 964 C2 Transformation Build Thread
#826
Originally Posted by Spyerx
[/left]
Lexan swirls and scratches... main reason. I can get to the weight I want I think w/o it.
#827
Back in she goes
#829
Let me know when she’s done, I’ll get a fun run scheduled and you can bring her out and flog her in the canyons.
#830
Not sure. Will see them tomorrow.
Main bits now are exhaust and power steering fab and alignment/setup
i need to get it up north cal for a few fun bits under the covers
#833
Wow those headers are gorgeous. Haven't seen them on Rothsports website before, so I'm guessing they're a pretty penny. How much work is it to re-add the heat afterwards?
#834
I've never felt a desirer to ask what an high-class-**** production cost until coming across your pics. total P ****... Please share your estimated figure of your drivetrain/chassis build cost - if able . Never mind the cost of the beautiful 964 or cosmetic repairs... Any thoughts on a more cheap build similar in nature?
#836
Where did you source?
#837
So when the motor went back in shop pressure tested the fuel lines before assembling and starting (yeah good thing right?) and well... 2 of the 3 or whatever the number is were leaking. They had already repaired one of them in the engine bay as the rubber was cracking, used an XRP connector I think its called? But when the other leak showed under pressure, needed to replace vs. just try to repair more. The ones in the engine (the 4 or 5 of those) are all newer and fine. It was the ones that run front to back. Basically, they are seeping at the rubber/plastic joints. So, in go new ones! Problem is, getting them from germany, which are still available, not terribly expensive in the scheme of porsche parts, but are on the SLOWWWW road.
Good new is interior done, and car is just about there.
Soon :-)
But bought a spyder a week ago to keep me entertained in the meantime.
Soon :-)
#839
[QUOTE=Spyerx;15098466]
Same exact thing happened with the front line ... being shipped in from Germany. The only one that wasn't changed. Delayed but worth it!
#840
Lines lines should be here this week. Interior 99% done just install seats and belts and a couple,panels.
Need glass in
polish car
steering rack
almost there.
