964 Forum 1989-1994
My 964 C2 Transformation Build Thread
Old 10-06-2017, 09:29 AM
  #736
911Jetta
911Jetta's Avatar
Really cool to see those cage pics. Love that it's tied into the rear shock mounts through the firewall. Man that must make the car feel so solid!
Old 10-07-2017, 03:18 PM
  #737
Spyerx
Spyerx's Avatar
Received 1,789 Likes on 1,089 Posts
We are making a few tweaks to the rear cage. Keep in mind this is more of a harness bar than a full roll cage, but it will add safety and allow use of harnesses on track.
This is a bit of a balance of some usable space in the back, but adding some chassis stiffness, and some safety.
Front hoop will pull a little bit forward, but it won't be fully tied to the B pillar, it will be welded to the chassis up near the window.
Rear mounts will attach at the shock towers with plates.
The rear X lower cross bars will drop down and also attach at the shock tower
Rear section will be spaced out a bit more.
We're using 1 3/4 tubing for front hoop and drops to rear shock towers. Rest is 1 1/2.
Pulling the bar fully to the B like on a race car requires additional bends and you lose OEM belt mount and OEM headliner mounts become an issue.
Old 10-09-2017, 02:39 PM
  #738
nolift911
nolift911's Avatar
B pillar tie ins?
Old 10-09-2017, 08:41 PM
  #739
Spyerx
Spyerx's Avatar
Yes, evaluating options. Looks like you had same situation! Is your build complete?
Old 10-10-2017, 11:52 AM
  #740
nolift911
nolift911's Avatar
Complete as in "relatively" complete....
I am starting the sunroof delete now -
Old 10-10-2017, 04:21 PM
  #741
Spyerx
Spyerx's Avatar
As complete as any of these are. They are living beasts!
I talked with the fabricator this AM and he is considering something like what you've done to tie it more directly to the B pillar. Unfortunately wanting OEM headliner, some clearance, OEM belt connection means other compromises... pros and cons to each.
Old 10-11-2017, 11:02 PM
  #742
Spyerx
Spyerx's Avatar
B pillar will be gusseted. Rear x not installed. Plates for shocks not done. Holes will be sealed up. Will have rs carpets.
Probably done tomorrow.
Old 10-16-2017, 01:52 PM
  #743
02m2
02m2's Avatar
is there a respary in its future?
Old 10-16-2017, 01:56 PM
  #744
Spyerx
Spyerx's Avatar
no. I don’t want it too nice. At some time in the distant future I’ll paint the whole car. Not now. Paint is serviceable as it is.
Old 10-17-2017, 12:46 AM
  #745
mooty
GT3 player par excellence
mooty's Avatar
Received 5,635 Likes on 2,318 Posts
pls be more specific
is this a german calendar, japanese calendar or mooty calendar
Old 10-17-2017, 12:53 AM
  #746
Spyerx
Spyerx's Avatar
cage work done. Paint tho.... and rest. Maybe I see it by Christmas? Lol.
Spanish calendar.
Old 10-17-2017, 02:05 AM
  #747
mooty
mooty's Avatar
^ well then just get them more jamon iberico then things speed up
Old 11-01-2017, 07:55 PM
  #748
Spyerx
Spyerx's Avatar
Old 11-01-2017, 09:02 PM
  #749
Super90
Super90's Avatar
Tell us about this "fuel filter re-location" mod you got going on....
Old 11-01-2017, 11:08 PM
  #750
Spyerx
Spyerx's Avatar
That’s top secret. Good for 20hp
Quick Reply: My 964 C2 Transformation Build Thread
