964 Forum 1989-1994
My 964 C2 Transformation Build Thread
Old 03-30-2016, 06:03 PM
  #481
Vandit
Vandit's Avatar
They're big washers.
Old 03-30-2016, 06:05 PM
  #482
C4inLA
C4inLA's Avatar
Thanks all... Glad I asked, learn something new every day.
Vandit,
Yes, large washer I put on outside. Except the Hd's are not flush to arm as those coil overs...
Old 03-30-2016, 06:33 PM
  #483
Mr.Alex
Mr.Alex's Avatar
Kept forgetting to ask, but I also want to swap out the OEM horn equipment and give it such more punch. Is it as simple as swapping the trumpets?
Old 03-30-2016, 06:42 PM
  #484
Spyerx
Spyerx's Avatar
Received 1,789 Likes on 1,089 Posts
I installed this, it's a lot louder than the stock horn setup. Plug and play, just installed some pigtails on the included plugs, put a connector on the end, etc.
http://www.rmeuropean.com/Products/1...G281-V841.aspx
Old 03-30-2016, 07:43 PM
  #485
HalV
HalV's Avatar
You're right, they are big! I installed mine the same way.
Old 03-30-2016, 08:04 PM
  #486
Spyerx
Spyerx's Avatar
I live dangerously. Part of my weight reduction strategy. :-)
Old 03-30-2016, 10:09 PM
  #487
HalV
HalV's Avatar
Certainly worth the risk with the size of those washers. :-)
Old 03-31-2016, 03:01 PM
  #488
C4inLA
C4inLA's Avatar
HaIV,
Can't tell by pic, you have gap at bushing to ARM, correct?
Old 03-31-2016, 06:44 PM
  #489
porsche mania
porsche mania's Avatar
Originally Posted by C4inLA
HaIV,
Thats how mine are installed, without the spacer the shaft doesnt pass through the top mount square.
Old 03-31-2016, 08:16 PM
  #490
HalV
HalV's Avatar
HaIV,
Sorry, I may not be able to check until this weekend.
Old 04-01-2016, 02:14 AM
  #491
Spyerx
Spyerx's Avatar
And out with the stereo amp and cruise control module, and cleaning up some maybe 20 yr old coffee or Coke. Nasty.
Old 04-04-2016, 09:32 AM
  #492
HalV
HalV's Avatar
HaIV,
Here's a pic of the gap.
Old 04-04-2016, 02:00 PM
  #493
Spyerx
Spyerx's Avatar
I didn't do much to the 964 this weekend other than drive it. Will do a few things this week - have an ABS pump coming, a new defrost/recirc button (it broke!), a heat mix servo, few other goodies.
I did take my 89 out for a PCH cruise with the wife early Sunday. I get home and close the sunroof.... "POP" (and my head goes FCK!!!!). I had noticed it wasn't sitting exactly right on the driver rear of the sunroof last couple times I used it. Well, I found the issue. And thank you Bentley manual...it shows the exact parts and how they are used for adjustment, found the little screw and a spring washer sitting in the rail, and a notched nut thing that allows height adjustment is MISSING. Crap. So pull the sunroof liner off and open about 1/2 way and start fishing int here with my trusty magnet reach tool thing... and FIND IT! Was able to assembly this thing while the roof was in the car, NOT easy due to the very tight access. But, have a properly aligned and functioning roof again. And while in there made sure other screws were tight. Oh, and fixed a balky rear slide electric seat switch with some contact cleaner. Old cars! Keep you busy.
Also, I ordered a T-Lock for the car, i should really put in my 89 too... mainly to save wear and tear on the lock mechanisms. I'll take the 8oz weight penalty LOL.
Old 04-04-2016, 02:29 PM
  #494
Streetdaddy
Streetdaddy's Avatar
You will LOVE the tlock! what a great invention. So easy to install ,too!
Old 04-04-2016, 03:01 PM
  #495
cobalt
cobalt's Avatar
Received 2,061 Likes on 1,237 Posts
Please explain????
Quick Reply: My 964 C2 Transformation Build Thread
