964 Forum 1989-1994
Bitter-Sweet Beginning
Old Dec 2, 2013 | 08:05 AM
  #76
DanielRS's Avatar
DanielRS
Wow, talk about difficult. The drone plates are on there very good. I think I will try dry ice next.
Just use a heat gun. Helped me a lot. Came right off.
Old Dec 2, 2013 | 09:54 AM
  #77
Wachuko's Avatar
Wachuko
Professor of Pending Projects
Thumbs up
Originally Posted by SausageCat
Started some color scheme photoshopping. What do you think?
This will look amazing!!!
Old Dec 2, 2013 | 10:01 AM
  #78
964Andrew's Avatar
964Andrew
My LHS tub was clean under the drone plate. Got myself a MIG on sale over the weekend. Will probably use big mirror to see what I'm doing cause going under is bit scary.
Old Dec 2, 2013 | 10:23 AM
  #79
964Andrew's Avatar
964Andrew
Definitely better option than ice. Was thinking that I might not even need the ice this week as temperatures will bottom out around -30C.
Old Dec 2, 2013 | 10:25 AM
  #80
964Andrew's Avatar
964Andrew
Thanks, paint day coming very soon I hope
Old Dec 6, 2013 | 01:03 PM
  #81
964Andrew's Avatar
964Andrew
Small update:
Temperatures here dropped to -38C and there is no heat in the garage. Engine drop is on hold right now as I have to weld RHS front jack-point. Waiting for at least 0C temperatures before I will attempt this. On the other hand I could just spray some water on the jack-point and attach it to the frame by freezing it to it
Other projects going as planned. Inspired by Singer 911 Im following some of their design choices. One of them is their key pouch pictured below.
Image found online (Singer 911)
I started experimenting with leather stamps and curing processes. This is the first try. More to come.
Old Dec 6, 2013 | 03:07 PM
  #82
Ken D's Avatar
Ken D
-38c? Are you located on top of Mt Columbia?
Old Dec 6, 2013 | 05:06 PM
  #83
964Andrew's Avatar
964Andrew
Nope, just Calgary, Canada.
Old Dec 6, 2013 | 05:25 PM
  #84
ginch's Avatar
ginch
Yup, she's chilly today!!! Cars coming a long nicely! Who's spraying the car for you?
Old Dec 6, 2013 | 05:44 PM
  #85
964Andrew's Avatar
964Andrew
Hoping for Screamin' Paint works.
Old Dec 17, 2013 | 11:10 PM
  #86
964Andrew's Avatar
964Andrew
Small update: Made floor panels.
Old Dec 18, 2013 | 10:47 AM
  #87
911Jetta's Avatar
911Jetta
Looks very nice. Tight fit.
Do you have a template that you can share?
Old Dec 18, 2013 | 10:57 AM
  #88
964Andrew's Avatar
964Andrew
I can make a template. But, because it is a tight fit some minimal adjustments would be required on part of others.
Old Dec 18, 2013 | 11:32 AM
  #89
911Jetta's Avatar
911Jetta
No worries. I've been wanting to do this for a while, and your pics finally tempted me to get off my ****.
I think boxy has a template for this.
Old Dec 18, 2013 | 12:10 PM
  #90
GeorgeK's Avatar
GeorgeK
Great plates. On the driver side, you may want to alter the outline, to allow room for the cable bundle to the DME. Ran into that issue with mine.
If you move your DME, disregard.
