964 Forum 1989-1994
Bitter-Sweet Beginning
Old 09-12-2016, 09:08 PM
  #301
964Andrew
964Andrew's Avatar
Originally Posted by onceover
Awesome to hear you're out driving it Andrew!
Couldn't help but notice that you've got the whale tail listed on kijiji already.
Hahaha, I'm going back to the classic look. I bought the turbo tail years ago and have since grown to appreciate the classic lines of 911.
Thanks!
Andrew
Old 09-13-2016, 12:33 PM
  #302
onceover
onceover's Avatar
Good choice! I've considered doing a turbo tail or duck tail multiple times but always go back to loving the factory look
Old 09-14-2016, 10:16 AM
  #303
Nostrathomas
Nostrathomas's Avatar
Very cool thread. Enjoy it often before it starts snowing....which we all know could be any minute now in Alberta, ha.
Old 05-25-2017, 03:37 AM
  #304
964Andrew
964Andrew's Avatar
Suspension time!
Waiting on Bilsteins and Eibach Pro that I got from a member here and was wondering if I need bump steer correction kit. Considering it because my steering rack boots are torn and I had "while in there" moment, so I can do the tire rods at the same time.
ER has a nice kit, but do I need it?
Thanks!
Andrew
Old 05-25-2017, 10:03 AM
  #305
911Jetta
911Jetta's Avatar
Wait for the suspension experts to chime in, but in the meantime...
I think you're fine with regular tie rods, but it all depends on how low you want to go? RS or lower?
I recently had Bill HD6s installed with HR springs (similar to your set up), there is a nice amount spring height adjustment. I'm at RS+15mm.
I need to upgrade my tie rods too, and was looking for something that would me a little more aggressive than stock. I was surpised that ER didn't have anything more aggressive than OEM spec tie rods.
993 guys talk about pinning their tie rods, is there something similar for a 964?
Old 05-25-2017, 10:49 AM
  #306
964Andrew
964Andrew's Avatar
Do you have a photo of your ride height? I would like to end up somewhere around RS spec. I will be slowly refreshing / upgrading all bushings and mounts. Nothing crazy, the plan is "Street ++" with occasional track day.
Thanks!
Andrew
Old 06-03-2017, 12:08 AM
  #307
964Andrew
964Andrew's Avatar
I was wondering if I can mount the the rear shocks assembled like that (normally they don't have the blue corrugated sleeve, just the top black solid one - right picture). I thought it will protect the shock better but thinking about it now the shock will depress under the weight of the car so the black solid sleeve will cover the exposed piston anyway.
Thanks!
Andrew
Old 06-03-2017, 12:48 PM
  #308
C4inLA
C4inLA's Avatar
Originally Posted by 964Andrew
Suspension time!
Thanks!
Andrew
Andrew,
I have just got my car back from alignment and have the Hd/Eibach setup and did put new tie rod outer pieces in. I am not sure I even understand "bump steer" term, but what would indicate a need for correction kit ?
Old 06-03-2017, 01:38 PM
  #309
964Andrew
964Andrew's Avatar
Bump steer is when your steering wheel turns on its own when going straight over bumps or irregularities on the road. When lowering your car you change the angle at which the steering rack operates. The bump steer kit is designed we to correct the angle back to stock.
Thanks!
Andrew
Old 06-03-2017, 02:29 PM
  #310
C4inLA
C4inLA's Avatar
I will watch for such issues. I have not checked ride height as the chap that did alignment did not supply me those numbers. He also works in imperial measurement vs metric. Appreciate it.
Old 06-09-2017, 11:06 AM
  #311
964Andrew
964Andrew's Avatar
Out with the old, In with the new. Some signs of wear due to failing bearing. Also, its nice to see the top of the engine still in tip-top condition!
Thanks!
Andrew
Old 06-09-2017, 12:02 PM
  #312
Super90
Super90's Avatar
Did you find, like I did, that the new alternator has a triple square fitting that is a different size than the tool in the factory tool kit? If memory serves, the tool kit is 10mm and the fitting is now maybe 9mm?? But I could be wrong.
Point is, if you have to change the belts by the side of the road, with the new alternator, you will need to have put a different tool in the bag, or you are stuck...
Old 06-09-2017, 01:25 PM
  #313
964Andrew
964Andrew's Avatar
I have not got that far yet. Waiting for single belt hub.
Old 06-09-2017, 01:27 PM
  #314
964Andrew
964Andrew's Avatar
BTW: Is the fan shroud magnesium or aluminium? I wanted to media blast it and just leave it unpainted.
Thanks!
Andrew
Old 06-09-2017, 04:31 PM
  #315
Super90
Super90's Avatar
Thanks!
Andrew
It's magnesium. See here:
https://rennlist.com/forums/964-forum/972064-fan-housing-replicating-factory-finish.html
Quick Reply: Bitter-Sweet Beginning
