Scantool and T-ODB
#31
Gents, it works on windows 8 no problem. I've got it running. Windows 8 is really only windows 7 with a skin so it will work fine.
I can post screen shots if you need them. Same install instructions as windows 7
#34
I've never tried a data logger on this. However, I've gathered all necessary info for the OBDPlot application in the T-OBD downloadable. The zip file include several URL's, here's one of them:
https://rennlist.com/forums/964-foru...rs-sought.html
Cheers,
Tore
Cheers,
Tore
#35
I´ve just ordered, Tore and looking forward what the features to heat + climate system are. Idling is allways without a problem after 6month wintertime, I´ve never done an adaptation!
#36
Hello all,
just receive the T-ODB and run it on my 964 C4 1991.
It's very direct but...
where wan I find the whole explaination of all the features??
the user guide just give a few screen shot...
The TIP woul dstand for Tiptronic , ins't it? (so Iuseless for me)
#38
Maybe it would be helpful to see your shots.
(ComPort 4 adjusting in ini file was successful
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
May be it don´t like 64bits?
#40
Did you see post #12 about the location of the ini file and admin rights? Perhaps that is related to what you are seeing?
#41
#42
I just reinstalled the software on my Dell 830 that I loaded Windows 8 (64 bit) on a few weeks ago. It worked fine when attached to the car and I got information and did an adaptation.
Make sure that the com port is set the same in the .ini file and the device manager. I used Com5
#43
#45
