Steering stop measurements
Hi. Does anyone have measurements or sketch to 10mm thick (part number 964.347.325.02) steering stops for 964? I have order that pieces over 1,5 month a go, and i havenīt never get that stuff on local importer. So i must made that pieces my self if i get measurements
Sorry my bad english
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
they are sold individually.
The length was about 2.5 - 3 cm square. Sorry I can't be more specific as they are installed. Stole this image from DC automotive. Note the circular area which is thinner metal.
Are you installing steering stops to prevent the inside of your tires from scraping the wheel well? If this is your intent, you could accomplish the same thing, by installing 5MM wheel spacers, which would not require an alignment. I believe that the original stops were 6MM, and the wider ones were 10MM.
