'Clicking' engine sound - trouble.
#106
Spoke to Craig again... it's bad news. The damage has caused bits of debris.
He's put back together the rockers and the noise is gone, but debris would have got in. The only way to see what damage that may have done would be to take apart the top end and dig further and further down...
At this stage it would mean a top end rebuild at the very least. The bottom end has done 117,000 miles.
I'm still debating what to do and whilst I need to have another conversation with Craig to make sure I fully understand the aforementioned - it seems a full rebuild is the way forward in this case. I couldn't face a bottom end failure after doing a top end, which is more likely considering the milage, and the fact I track the car. I had the conversation with Em and I have the white flag from her.
To say I prepared for the worst would be true, but still I'm seriously down about the whole thing.
Guidance would be appreciated... I may sell.
#107
Technical Guru
So the adjusting nut came loose and was launched around the valve train? Do you have photos of the debris or the score marks on the camshaft housing?
#108
If you have it stripped down 'in case' there is a problem and they find nothing I think you're going be a little upset about the expense you've gone to. So, if there are now no worrying noises and the engine runs fine, I would run it for a bit, see how it goes and then give it an oil and filter change and check for debris in the oil.
Hopefully it will all go well and you can get the rebuild done at a more convenient time. If you start to hear, feel problems with the engine then you can reconsider your options.
#109
Cheers
Simon
#110
I assume a leak down test may give more of an indication?
Agreed and this is what Craig is suggesting. If however something goes wrong, could result is big damage. More than what has already been done. He says there's just no way of knowing the extent of the damage until you start stripping or until it goes wrong. I don't know - is this a risk worth taking?
From my understanding it's been put back together to gauge how far the damage has gone. Agreed the worst case would be to create more damage. Which is why continuing to strip down for investigation would make sense.
#111
Frank,
I'm confused, you spoke to Peter again and the damage has caused debris?
What damage?
You havent said previosly there was any confirmed damage or what was damaged, or have I missed something?
What damage?
#112
Any junk that got in would be in the oil .
The oil gets passed through the oil filter .
The oil filter traps the junk .
If the motor is running fine , send in an oil sample to see what is in the oil .
Pull open the filter and see what it has caught .
If the oil test comes back with no problems ,
if the oil filter shows no problems ,
I'd run the motor .
I'd run the motor .
#113
It sounds like they've just taken the cam covers off, noted a problem, rectified what's visibly wrong and having corrected that reassembled....run the engine and noted the existing noise has gone....
...and I must say that I too am confused about the logic of running an engine where there's some evidence of debris ...even if the damage is already done. I suppose the logic is that if damage is already done, then at idle there's not a lot more damage that can be done with the engine in a steady state and with little if no loading.
Frank, DO NOT CONSIDER SELLING....you would only kick yourself later.
Or one of us would
If it were me I'd get a fixed price for a strip down and rebuild only....to diagnose what's the prob and what needs replacing...and yes that would be for top and bottom.
Then you can consider what you do next with a clear idea of what it will cost to get the car either running or with pertinent upgrades.
Just my 2p worth!
Or one of us would
Just my 2p worth!
#114
I'd be interested to hear what exactly the damage was and what might have caused it.
I swear my car has had a similar tick since I got it 5k miles ago. The PPI showed consistent compression and leakdown #s.
I've just recently adjusted the valves and the tick is still there. I didn't really investigate the valve train for damage when I had it open because I didn't suspect a problem and w/o knowing specifically what to look for, I probably don't have the expertise to identify anything just by looking at it.
#115
Thanks for all the feedback gents.
As said, this is the headlines I took away from the conversation and my amateur understanding of them. A thorough conversation next week will give more details.
The damage is to the rockers - I assume the debris comes from them.
It seems this is the next logical step in evaluating.
Yes that's what has been done so far.
The logic was to let me know the damage they could immediately see, rectify it, see if it made the difference and then call me to see what steps I wanted to take next.
To me it seems the next logical step after assessing a leak down test and condition of the oil and filter. It's just once I've done that - then I'm fully committed to putting it back together again. I decision I haven't made yet.
I'd run the motor .
I'd run the motor .
#116
Oil change and run it. If you're going to do full rebuild now 'just in case' then the cost differential in repairing further damage can't be much. As others have said, oil and filter change should deal with the worst if not all debris. Any damage now is already done. Seems a no brainer...?
#118
PS> Someone call The Good Doctor!
#119
It does sound, from what you've described so far, that you may have 'got away with it' and for the sake of a couple of filter and oil changes after a few gentle/leisurely drives you'll know more clearly whether you truly have.
#120
I'm not an expert by any means
But if the rockers are damaged in some way, it's likley to be caused by fatigue, not by something else deeper in the engine surely
In what way are they damaged?
I'm with the majority here, change the oil and filter, use it and ponder the next step
What is GT Ones opinion on the best course?
